problem w/ door panel removal
Old Jan 30, 2008 | 10:09 PM
SDZR-1's Avatar
SDZR-1
Cruising
Default problem w/ door panel removal
I have remove all the screws along bottom, in front part of door, one screw in the center of the door handle, and one in the rear of the door. are there more that I'm missing? the panel is loose and seems to be holding up in the center around the handle area, which made me think i forgot something. any help is appreciated. thanks
Jarvis
Old Jan 30, 2008 | 10:12 PM
rich653's Avatar
rich653
Jarvis
Can't help unless we know what year you have????
Old Jan 30, 2008 | 10:18 PM
staugur's Avatar
staugur
Have you popped off the plastic door lock-the one with the red bit on it that slides back and forth? Theres also two screws in the bottom of the door pull,the bit below the handle.
Old Jan 30, 2008 | 10:25 PM
94z07fx3's Avatar
94z07fx3
This varies by year. But on the the two that I've had apart there are three screws that hold this insert on. One you can see easily(2). One is behind the lamp (1)(the cover pops off) One is under the lock lever(3).
Old Jan 30, 2008 | 11:37 PM
SDZR-1's Avatar
SDZR-1
Cruising
it's a 91 zr-1...thanks for the illustration...now i just have to find them...how do i get the door lock slider out?
Old Jan 30, 2008 | 11:56 PM
7.5mercury's Avatar
7.5mercury
Default lock slider removal
on my 93, these are black and just pop out.
If you search around on the Corvette websites, this one and others, you can find step by step to do this job.
Good luck.
Old Jan 30, 2008 | 11:59 PM
SDZR-1's Avatar
SDZR-1
Cruising
thanks....now i feel like a real idiot, i went out to try find these screws and the doors were locked. I must have locked them when i was messing w/ it earlier. I dont have a spare set of keys, and I took the electric lock switch out. I'm gonna deal w/ it tomorrow...haha.
Old Jan 31, 2008 | 10:13 AM
7.5mercury's Avatar
7.5mercury
Default Bummer
Sounds like something I would do.
Try doing a search on "locked out". Can not remember, but I think I saw this somewhere.
Old Mar 26, 2008 | 12:02 PM
catskill3's Avatar
catskill3
4th Gear
On my Dad's 93 we discovered the passenger door is different due to the arrangement of the switches... on the passenger door we found that under the window switch (which pops out) there is a hex bolt behind there... careful not to drop the damn thing in the door. I managed not to drop the thing, but did eventually drop a socket in there. If that thing rattles around I am going to be ^&*@!
Old Apr 27, 2008 | 03:33 AM
Z51JEFF's Avatar
Z51JEFF
Once this insert is removed do you have to fight getting the door panel off over the handle or is there enough room with the insert removed the panel comes off easy.Ive got to remove both door panels to get access to the outside moulding studs inside the door.
Old Apr 27, 2008 | 08:46 AM
pianoguy's Avatar
pianoguy
When you go to put it back together, make sure to put the shortest screw in behind the light by the door handle.
Old Apr 27, 2008 | 11:23 AM
Tominator's Avatar
Tominator
Default plasitc slide
To add to Staugur's , if you need to pop the lock-slider out (if this applies), use a small pointed angle Awl to slide behind it on the long end. It should "pop" away from the bar it is on. Then, it still takes careful manuvering of the panel not to ding it up. You might want to take a look a "Haynes" or simlar repair manual for your year Vette at your local autoparts store (or buy for about $12.00). They generall have good photos on this type of thing. Good luck!!!
To problem w/ door panel removal
