Weird headlight problem
Old Feb 1, 2008 | 02:49 PM
MikeAtOldeBayRV's Avatar
MikeAtOldeBayRV
4th Gear
Default Weird headlight problem
Hi everyone, great site! I have a weird problem with the right headlight on my 85. I replaced the headlight motor with a rebuilt unit from Dino's because the motor was toast. The headlight will open and close once or twice at the most and then binds up about 1/2 inch open. I cannot rotate the headlight with the manual ****. If I loosen the bolts holding the whole assembly, then I can now use the **** to open or close the light. As soon as I tighten the mounting bolts again it will work fine through one or two cycles and bind again. I have plenty of clearance, I have been careful in how I tighten the assembly down, have not actually torqued the bolts but have been careful, using a sequence like you would tightening down a head. This is driving me nuts! I have to drive around with the lights up and motors unplugged. Have searched the forum with no luck. Anybody have this happen? Any suggestions? Thanks!
Old Feb 1, 2008 | 03:07 PM
bd2626's Avatar
bd2626
Don't know if this is the right answer or not but did you check the bushings/gears when you replaced the motor?
Old Feb 1, 2008 | 03:38 PM
MikeAtOldeBayRV
4th Gear
The replacement was a complete, rebuilt unit, gears and all. The binding part is what has me confused. I loosen the headlight assembly mounting bolts and it frees right up and works perfectly once or twice and then binds up again.
To Weird headlight problem
