1989 MN6 Axle ratio
Old Feb 1, 2008 | 04:48 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Default 1989 MN6 Axle ratio
According to 1989 Factory specs on Rogers Corvettes G92 is the code for performance axle.
In my owner's manual I think it said 3.07 were base gears -- though it might be lower for base autos. (I don't have the manual handy.) Because I didn't have G92, I thought I had 3.07.
OTOH, I thought I read recently that all 1989 6spds (first year for the MN6) had 3.33 gears. I don't have a Z51.
I can't check by turning wheels (front's on jack stands).
Can someone confirm if I have 3.33 gears....
gp
Old Feb 1, 2008 | 05:00 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
A few early 1989's had 3.54 gears, mine does. Most had 3.33 with the 6 speed. You should have a G__ code that tells you axle ratio. Look in the RPO FAQ's I don't remember them off hand.
Old Feb 1, 2008 | 05:04 PM
tequilaboy's Avatar
tequilaboy
From the rpo faq:
G44 - 3.07 Rear Axle Ratio
G87 - ring gear 8.50 inch
G92 - Performance Axle Ratio
GHO - 3.54 axle ratio
GM1 - 2.59 Rear Axle Ratio
GM3 - 3.45 Rear Axle Ratio (8.5 in. Ring Gear)
GT7 - 3.33 rear axle ratio
GU2 - 2.73 Rear Axle Ratio
Old Feb 1, 2008 | 08:30 PM
vader86's Avatar
vader86
GHO: 3.54 available on early-89 6 speeds, and as an option on a few later years.
GT7: 3.33 available on Late-89-90 6speeds
GM3: 3.45 standard rear for later 6speeds
Old Feb 2, 2008 | 11:13 PM
GREGGPENN's Avatar
GREGGPENN
Thanks! My codes say GT7 so I have a 3.33....
(That makes me feel better cause I thought I had 3.07 econ/highway gears. The dang thing is about 1500rpm at 70mph on the highway in 6th. Now I know it's really the 6th gearing).
gp
To 1989 MN6 Axle ratio
