hotcam kit,ewp,cloyes double install. help please?
Old Feb 2, 2008 | 02:22 PM
vettin_it's Avatar
vettin_it
Default hotcam kit,ewp,cloyes double install. help please?
Im tackling all this in the next couple days and was just looking for advice or things to be aware of.
where can I find torque specs for everything?
what is the best sealant to use on the intake manifold?
Ive never done valve springs before. do I need to use shims with the hotcam kit?
Im sure I will have lots of questions soon!
thanks ahead of time for any and all help!
Old Feb 2, 2008 | 02:27 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Learn to use the search feature of the forum. It's the best way to find the answers to your questions.
Randy
Old Feb 2, 2008 | 02:41 PM
96GS#007's Avatar
96GS#007
1) Factory Service Manual
2) Right Stuff (yes, that's the name of it)
3) Depends
Old Feb 2, 2008 | 02:50 PM
vettin_it's Avatar
vettin_it
How do I find it if shims are required? I believe they came with the kit. should I just use them?
Do I need to take the passenger motor mount out and jack that side of the engine up to remove the cam?
Old Feb 2, 2008 | 03:18 PM
STL94LT1's Avatar
STL94LT1
You will probably need shims to get an even installed height on all of the valve springs. However, some just install the springs and don't worry about installed height. You'll also need new valve seals if you shim the springs.
If shims came with the kit, more than likely they are the same valve seats/locators as you already have on your heads.
Old Feb 2, 2008 | 09:36 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
Here's a link with a good overall write-up.
http://www.hashmarks.com/techtips/hot_cam.htm
Old Feb 2, 2008 | 10:46 PM
Hotred94's Avatar
Hotred94
The kit comes with shims--use them. The kit does not come with valve stem seals--install new ones. Good luck.
To hotcam kit,ewp,cloyes double install. help please?
