1996 LT4 Cooling fan question
Old Feb 2, 2008 | 10:43 PM
JamesRS's Avatar
JamesRS
Corvette Enthusiast
Default 1996 LT4 Cooling fan question
I recently bought a 96 LT4 and am concerned about the engine temps. Just cruising around in the cool winter air I am noticing that the car is running in the upper 220's to lower 230's and that makes me think that in the 115 degree temps it going to overheat. Since I live in the Desert I try to keep my cars running as cool as possible. I realize that Chevy set the cooling fans to come on at 228 and the secondary at 237, but I would like them to come on sooner. How can I get the fans to come on sooner? do I have to send my ECM to a tuner shop? Can I acquire some software to set these parameters myself through my laptop? Do I have to buy a Hyper programmer do this and is it worth it?
Any advice is appreciated guys.
James
Old Feb 2, 2008 | 10:52 PM
STL94LT1's Avatar
STL94LT1
Check the front of your radiator for debris. Your car shouldn't be running that hot in cool weather. Are those highway temps?
Old Feb 2, 2008 | 10:58 PM
JamesRS's Avatar
JamesRS
Corvette Enthusiast
Yeah, I already cleaned out the junk in front of the radiator and the few leaves that were caught up in between the condenser and radiator. the temps that I am referring to are in city driving. Idling around and going from stoplight to stoplight the temps get up to over 230 which makes me uncomfortable. I'd like to see them lower. On the freeway they stay right around 195 - 205 which is fine. I figure if I could get the fans to come on sooner, I'd be okay.
Old Feb 2, 2008 | 11:01 PM
STL94LT1's Avatar
STL94LT1
OK, those temps are about right.
You can reprogram the fans to lower the coolant temps in city driving. Send out the PCM, reprogram by LT1 Edit, or us a Hypertech prorammer.
Old Feb 2, 2008 | 11:03 PM
94z07fx3's Avatar
94z07fx3
Originally Posted by JamesRS
  1. How can I get the fans to come on sooner?
  2. Do I have to send my ECM to a tuner shop?
  3. Can I acquire some software to set these parameters myself through my laptop?
  4. Do I have to buy a Hyper programmer do this?
  5. Is it worth it?
1. Reprogram. Clicky
2. Not if you're willing to DIY.
3. Yes.
4. No.
5. In the desert, I'm sure that it is.
As mentioned already, check for debris in the radiator between the condenser and the radiator. Also, check for bent fins and make sure there is no air in the system by opening the bleed screw on top of the thermostat housing on a warm, running engine until only scalding hot coolant comes out into the rag that you have there to catch it.
Old Feb 2, 2008 | 11:07 PM
WickedVetteLT4's Avatar
WickedVetteLT4
Mine runs way cooler than that but i have an electric water pump, 160* stat and my fans are programmed to come on cooler as well. Mine runs cooler than 185 when its cool outside but averages 185 most of the time...
Old Feb 2, 2008 | 11:17 PM
pianoguy's Avatar
pianoguy
Is your air conditioning on? I believe the fans come on with the AC as well.
Old Feb 3, 2008 | 01:49 AM
Arkybill's Avatar
Arkybill
I've got a 94 LT1 auto and it runs about 200 in the summer with the A/C on. In the winter, it runs about 209 -this is the digital readout, not the analog guage.
If you want to cool things down in the winter, turn on the defroster, it makes the A/C run and the primary fan runs all the time. I don't like the temps this high, but, I've gotten used to it. I use Datamaster to see what's going on, I intend to get a different program to change the fan temps, but, haven't yet.
I don't get much stop and go traffic, if I did I'd probably get the program to change the fan temps.
bill
Old Feb 3, 2008 | 07:58 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
James
If it bothers you reprogram the primary fan to kick in around 210. Changing the thermostat won't accomplish anything.
Old Feb 3, 2008 | 11:33 AM
JamesRS's Avatar
JamesRS
Corvette Enthusiast
I think that's what I'm going to do. I figured I'd look into getting a hyper programmer to set the primary fan to come on at 210 and the secondary to come on at 220. This should keep the car down where I feel a little better.
Anyone got a hyper programmer for sale?
James
Old Feb 3, 2008 | 12:17 PM
Speed of Heat's Avatar
Speed of Heat
Your 96 does not have a primary and secondary fan. Boths fans operate together in lo or hi.
Old Feb 3, 2008 | 01:39 PM
Hotred94's Avatar
Hotred94
You should consider PCMforless tuning, it costs way less than a hyper programmer and you can get more parameters tweeked and a better tune.
Old Feb 7, 2008 | 05:22 PM
the blur's Avatar
the blur
To 1996 LT4 Cooling fan question
