Injector length question
After popping the fuel rails and replacing the injectors, I was not able to get all 4 injectors to stay seated in the rail or manifold
I pulled them out and put the old against the new and the replacements were shorter. O-ring to O-ring on the Multechs is 65mm. Length on the replacements, and others I have checked into, is 60mm.
Has anyone else run into this problem before?
Because I had several dying multechs, I had to make them work. I now have 2 replacements on the rear passenger side and 2 on the drivers side front. This was the only way to move the fuel rails enough to keep the o-rings in place without leaks. It does work, but I'm sure my flow rates and spray patterns are all screwed up.
Any ideas? Thanks
When replacing mine, I was told the injectors would go in without the clips. I couldn't get them to stay seated in the manifold/fuel rail without the clips.
Does anyone have an old injector that they will measure from o-ring to o-ring? I'd appreciate any info you can share.
