oil filter adaptor
Old Feb 3, 2008 | 04:11 PM
hman1987's Avatar
hman1987
Default oil filter adaptor
Any tricks on removing the oil filer adaptor. I need to change the pan gasket and can't drop the pan with it in the way. Unless someone else knows a way to get the pan out. I've tried everything.
Old Feb 4, 2008 | 11:31 AM
hman1987's Avatar
hman1987
Disregard. I got the adaptor out and the pan followed. Now to clean everything up and put it back together.
Old Feb 4, 2008 | 05:27 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default adaptor
is this the oil/water cooler under the oil filter? replace the gasket where it meets the block.
The gasket/o-ring is no longer available from Chevrolet. Go to a auto parts place that sells Fel-Pro complete engine gasket sets, and look on the box for the o-ring part number and order that one item.
Old Feb 6, 2008 | 11:38 PM
Slalom4me's Avatar
Slalom4me
Originally Posted by coupeguy2001
Go to an auto parts place that sells Fel-Pro complete engine gasket
sets and look on the box for the o-ring part number and order that
one item.
This is a promising answer to a gasket question. However, it may be
that only some FelPro boxes list part numbers for the individual items.
A full set that I have here does not provide part numbers for the
contents. The external label only details the contents by quantity,
description and country of origin. A check inside did not turn up a
sheet with a list of part numbers.
FWIW - the external label identifies the gasket as
"1 - Oil Cooler Adaptor Seal . United States"
Old Feb 7, 2008 | 12:27 AM
rodj's Avatar
rodj
I've using a ring off a oil filter with no probs.
To oil filter adaptor
