1984 LCD Display
Old Feb 4, 2008 | 06:39 AM
tgtexas02's Avatar
tgtexas02
Default 1984 LCD Display
Cluster lighting causing me problems. Sometimes everything lights up fine and sometimes it stays dark. You can gentlely tap the housing and it might restore. I don't think the problem has anything to do with grounds exterior to the cluster. Reminds me of something like a loose pin, some widget heating up, or a cold solder thing. I happen to have an extra bottom board but I don't know what it came out of. I am thinking that I might try changing to this extra board. My car is an automatic and the board in question has the number "6572053688" with bar codes. Anybody know if this will/should work for 84, auto with cruise?
Old Feb 4, 2008 | 06:41 AM
comp's Avatar
comp
Old Feb 4, 2008 | 07:56 AM
WW7's Avatar
WW7
You say that you don't think its the ground but that is the first thing I would suspect with intermitent operation. Do a search, I think there is a post here on how to reground the display. WW
Old Feb 4, 2008 | 08:18 AM
qws's Avatar
qws
http://www.batee.com/corvette/index.shtml
Old Feb 4, 2008 | 09:53 AM
tgtexas02's Avatar
tgtexas02
Terrific site! I have Gordan's book but it only gets you so far. I should have stated that I do suspect it it a ground issue but internal to the cluster. I actually think it is in the D3 pin circuit on the board. Based on the site you gave me, I am going to touch my solderinig tip to suspect points like right behind the board's D3 male connector and the tall pin that connects the boards together. Thanks a million.
Old Feb 5, 2008 | 02:26 AM
tgtexas02's Avatar
tgtexas02
Just a little feedback for others on what I did. I did touch up the tall pin connectors with solder and I bridged the photo cell with a wire. Before I did these things, the cluster would light up with ignition on, then go dim, them only the direction signal lights would stay on--the rest was dark. Now, everything stays on and is bright. I won't have the photo cell but don't really care. I can dependably see everything all the time now. Problem solved
Oh, I have a couple of old boards with photo cells in them and I probably will replace the bad one in my cluster someday? Not that difficult of fix now that I have a little experience.
Old Feb 5, 2008 | 09:35 AM
qws's Avatar
qws
Glad it worked out for you, and to see you followed up on the thread.
Old Feb 5, 2008 | 01:56 PM
pmihaltian's Avatar
pmihaltian
Slingshot
WELL DONE !
To 1984 LCD Display
