need steady fuel pressure
Old Feb 7, 2008 | 02:42 AM
sick-punk's Avatar
sick-punk
Default need steady fuel pressure
Ok i search every where with no luck. I just got a fuel pressure guage and the stock pump check valve was leaking fuel back into the tank and the fuel pressure at idle ranged from 37 to 42psi needle bouncing like crazy, with vacume 45 to 48 without vacume still bouncing, went through trouble shooting in th fsm to find that out so i replaced it with the 255l pump racetronics kit and heres the info.
pressurizes whe primed KEY TURNED ON 47psi then settles at 42 or 43psi doesnt bleed off for at least 3 days still had 21psi at third day.
with engine running running the needle bounces from 37 to 42 43ish area with vacume, 44 45 to 48 with out vacume, why wont my fuel pressure hold steady
additional info, 86 tpi #24 five-0 injectors all ohmed within each other around 15.....used injector noid light all pigtails-harness checked out checked out.....i appear to have adjustable regulator cause there is a adjustment screw in the top.. didnt do much when i tried to adjust the fuel pressure.runs crappy when first started gets better when it warms up.
Old Feb 7, 2008 | 08:22 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I bet if you replace/repair the AFPR, your bouncing needle will be gone. My Holley reg is rock steady.
Old Feb 7, 2008 | 09:18 AM
evmlarry's Avatar
evmlarry
I wish I had the same results with my Holley. The dumb diaphragms kept separating from the metal piece that the spring rests on for me. I went through two of them before calling it quits. The Holley is definitely designed for convenience with the size of that dial. Much easier to turn than sticking a little 5/16 wrench in there and trying to turn a little bolt.
Old Feb 7, 2008 | 09:33 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Fuel pressure regulator problem
Old Feb 7, 2008 | 09:34 AM
RRT vette's Avatar
RRT vette
I've got a Holley as well. Holds steady the whole time on my gauge. Wonder if maybe the fuel pressure gauge as a malfunction. Have you tried a different gauge before taking the plenum off to check the FPR?
Old Feb 7, 2008 | 10:56 AM
mseven's Avatar
mseven
pulse dampner in tank can cause that also.
Old Feb 7, 2008 | 11:20 PM
sick-punk's Avatar
sick-punk
thx for the replys guy, i guess ill be buying a new afpr probably holley..../. it cant be the pulsation dampner the raacetronics kit replace it with a high pressure hose....plus it did it before the kit was installed.....ill let you guys know how it goes
Old Feb 8, 2008 | 01:00 AM
RRT vette's Avatar
RRT vette
Have you tried a different fuel pressure gauge? Hate for you to replace a good FPR.
Old Feb 8, 2008 | 03:50 AM
sick-punk's Avatar
sick-punk
gauge is brand new, so it should be good... if i can find another ill try it if not that holly afpr looks great, kinda want one just by looking at it...
Old Feb 8, 2008 | 03:56 AM
RRT vette's Avatar
RRT vette
I like my Holley. When I bought it, there were no replacement diapharams but I read now that they're available.
Old Feb 8, 2008 | 10:28 AM
wa4ky's Avatar
wa4ky
Acct suspended by request 12 Dec 2012
Default Pressure Leak Down?
I have steady fuel pressure while running at all conditions, but the pressure will leak down to almost zero within about 2 minutes of turning the engine off. Is that normal or is the system really supposed to hold pressure indefinitely? If it leaks down and is not supposed to, what problems could that cause?
Thanks!
Old Feb 8, 2008 | 12:46 PM
deerra's Avatar
deerra
Minutes ago I just posted a question asking the same thing. How long does the fuel pressure hold with the engine off? Or, how long should it hold if all things are as they should be, ie; working correctly.
Old Feb 8, 2008 | 07:11 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Call ECS
Old Feb 9, 2008 | 03:24 AM
sick-punk's Avatar
sick-punk
ecs what-whos that....... fyi fuel pressure should hold at least overnite....
Causes of a leak down...
faulty fpr
leaky injectors
leaky or faulty cold start valve
leaking pulsation dampner
faulty check valve in fuel pump
a leak down of two minutes is probably check valve or pulsation dampner-dampner can be replaced with high pressure hose and a couple of hose clamps hope this helps
Old Feb 9, 2008 | 04:23 AM
RRT vette's Avatar
RRT vette
Thanks!
If the fuel pressure leaks down within 2 minutes, you have a leak in the fuel system. There are about 8-9 different places the fuel can leak at and sick-punk named the common ones. It's really not a big deal unless the leak is external, injectors, or fuel pressure regulator related. There are a couple simple test that can be done with a fuel pressure gauge and a pair of pliers to trace where the leak is.
To need steady fuel pressure
