Removing ASR
Old Feb 12, 2008 | 09:56 AM
wpsrea's Avatar
wpsrea
Originally Posted by RichS
Yes, 92-93 has one.
When I put the auto in my 96 I made my stock bracket accept a kickdown cable so it goes from the TB to the transmission. The TV cable was off a LT1 Z28 from the dealer for around $25. Then you should be able to use the throttle cable listed above.
RichS, Do you have any photos that show how you did it? As I understand it, you used the Lt1 Z28 throttle cable and the Z28 TV cable?
Old Feb 12, 2008 | 12:16 PM
2bar-c4's Avatar
2bar-c4
Can you turn of the ASR in the computer with Tunerpro and then just run a new cable?
Old Feb 12, 2008 | 12:20 PM
DVNCI's Avatar
DVNCI
Well not exactly. It's actually not a PCM function.
It's a function of the CCM and ABS computer itself I believe.
But, if you get rid of the cable itself then the system can't retard throtte but it could still retard spark and fuel.
I'm redoing the complete brake system on my car so I got rid of everything related to ASR or ABS including the ABS sensors themselves, but my car is not a daily driver and never sees rain, not sure if I would do it on a daily driver or not.
Old Feb 12, 2008 | 12:35 PM
2bar-c4's Avatar
2bar-c4
I didn't know the CCM and the ABS could control the spark and fuel through the PCM? I wonder if that is one of the hard coded things that cannot be altered by tunerpro. I know there is a place to select it on or off.
Old Feb 12, 2008 | 01:57 PM
DVNCI's Avatar
DVNCI
Yep!
No way to turn that off through the PCM itself that I have seen. I think Tunercat has a traction control toggle but I think that only applies to Fbodies - I don't think it does jack on a Vette
Old Feb 13, 2008 | 11:43 AM
93 ragtop's Avatar
93 ragtop
Sorry to take so long getting back with the part no. but here it is. GM 12550676. As someone already said, Its from a F body.
As far as hooking back up the TV cable, can anyone say how the 85-91 hook up? If it is directly to the TB you may be able to use one from that era.
Also, You will loose cruise control when eliminating the ASR
Old Feb 13, 2008 | 03:18 PM
wpsrea's Avatar
wpsrea
Thanks for the cable part number. I hadn't thought about the 85-91 TV hook up. When was the "460" transmission first used? No problem with the cruise. I never use it any way. Just one thing to get out of the way.
Old Feb 13, 2008 | 06:58 PM
hgh pwr's Avatar
hgh pwr
I have the 4l60e on my 94 not sure but 93 might have one also.I would like to remove the asr also so If any figures it out please post your result.
Old Feb 14, 2008 | 07:42 AM
93 ragtop's Avatar
93 ragtop
The "E" version came out in 94. All 93's were non electronic.
Old Feb 14, 2008 | 01:59 PM
wpsrea's Avatar
wpsrea
'92 and '93 both the same? Non electronic.
Old Feb 15, 2008 | 06:28 AM
93 ragtop's Avatar
93 ragtop
Yes, The E version did not come out until 94. It needs the pcm to control it, and the 92-93 all have the non E version.
