Removing ASR
Old Feb 7, 2008 | 03:09 PM
wpsrea's Avatar
wpsrea
Default Removing ASR
Has anyone ever removed the ASR system from an LT1/auto. I would like to remove it on my autocross car. The biggest problem seems to be the TV cable. Any thoughts?
Old Feb 7, 2008 | 04:28 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
LT1 has a TV CABLE ?
Old Feb 7, 2008 | 07:10 PM
BAM92's Avatar
BAM92
would love to get rid of mine too. Never use it.
Old Feb 7, 2008 | 07:54 PM
aminnich's Avatar
aminnich
It can be done in less than a second. Push the OFF button.
PS--4L60Es do not have a TV cable.
Old Feb 7, 2008 | 09:04 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I think he meant the ASR's TV cable.
On/Off button (Off is Off)
TV Cable off (will decrease timing)
Unplug the ASR (will give/Pop-up you codes)
Old Feb 8, 2008 | 02:32 AM
BAM92's Avatar
BAM92
My reason is more for asthetics. Then I can use the button for something else like arm the meth injection. Everything topside in my engine compartment is chrome or polished. Would be nice to see the headers without the asr in the way.
Old Feb 8, 2008 | 05:56 AM
93 ragtop's Avatar
93 ragtop
I can give you the throttle cable no. that will allow you to go from the peddle to the TB. (I have it laying inside my 6sp. car.) And if you contact Baldturbofreak, he can tell you how to install a resistor in the wiring so you can remove the ASR module.
But as far as how to re-connect the TV cable, I have no idea. And yes, 92-93 have a tv cable.
Old Feb 8, 2008 | 11:47 AM
wpsrea's Avatar
wpsrea
I fully understand about pushing the button. I just want the system out of the car. And yes, according the FSM there is a TV cable on the '92. It appears that is going to be the biggest problem. But someone out there must have done it.
Old Feb 8, 2008 | 10:36 PM
BAM92's Avatar
BAM92
I would be interested in the number of that cable when you get a chance. Wasn't it off a F body car with no asr? I can care less about keeping my car factory. I will contact BTF for that resistor too. Thanks.
Old Feb 9, 2008 | 12:10 AM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
I'd leave it alone. Something's bound to get screwed up.
Old Feb 9, 2008 | 06:55 PM
Mojave's Avatar
Mojave
I removed the ASR from my 96 Auto. I took everything off and got an LT1 f-body cable (I think I got a 95). Mine was a bit long, but I got it to work. No tech on TV cable for 92-93. You could just remove the light from the DIC. Once you unbolt it, the bulbs pop right out from the DIC. No more light!
Old Feb 9, 2008 | 07:16 PM
robertallen's Avatar
robertallen
when i turn my asr off it retards the timeing????????
Old Feb 9, 2008 | 07:38 PM
Road Agent's Avatar
Road Agent
Old Feb 10, 2008 | 11:18 AM
wpsrea's Avatar
wpsrea
Hey Mojave, I thought your '96 was a 6 speed i.e. the track car. Or are you talking about another one?
Old Feb 10, 2008 | 02:28 PM
Midnight LT4's Avatar
Midnight LT4
I'm seen modules for other cars (Mustangs) to make the default "traction control off" each time the car is started. I have yet to autocross my Vette but I can only imagine how annoying it will be to have to remember to turn off the ASR each run.
Old Feb 10, 2008 | 04:26 PM
Mojave's Avatar
Mojave
You're right. I was really tired when I typed that. Yes, mine is a 6 spd.
Old Feb 11, 2008 | 04:58 PM
DVNCI's Avatar
DVNCI
I don't have the P/N I used but I'm 100% sure the one I used was off a 95 Z28.
I'm probably going to check on running the one that Lokar has though, I think they've got a nice braided one that would look much more trick.
To Removing ASR
Old Feb 11, 2008 | 05:09 PM
RichS's Avatar
RichS
Yes, 92-93 has one.
When I put the auto in my 96 I made my stock bracket accept a kickdown cable so it goes from the TB to the transmission. The TV cable was off a LT1 Z28 from the dealer for around $25. Then you should be able to use the throttle cable listed above.
Old Feb 11, 2008 | 09:50 PM
JonnyAngle's Avatar
JonnyAngle
I love the way I look when I inject meth
Old Feb 12, 2008 | 02:31 AM
BAM92's Avatar
BAM92
If I stop using the meth, my motor will have to go to rehab. Crack and piston, don't go together well. I am gonna leave well enough alone and leave it in.
