Headman Elite Headers.....Opinions?
Old Feb 8, 2008 | 08:54 PM
5speedC4's Avatar
5speedC4
Default Headman Elite Headers.....Opinions?
I was considering buying some Headman Elite headers.....used.
What does the forum think of them?
For my 1988 L98 corvette......Stock motor with miniram and free flow exhaust system.
Old Feb 8, 2008 | 09:25 PM
JackDidley's Avatar
JackDidley
They say the fit is good. You will need to adapt to the rest of your exhaust. if they are used the O2 bung should be there. You need that. I would not use any headers that have not been ceramic or Jethot coated. Something to consider.
Old Feb 8, 2008 | 09:44 PM
JLeatherman's Avatar
JLeatherman
The elites are pretty good headers. You can get ball/socket adapters that have the O2 bung in them. Fit is good as long as you don't have an oil cooler adapter. They hit that on my car. I've heard the coating on them is pretty tough (get the coated ones).
Old Feb 8, 2008 | 09:47 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
They hit the hose right? Go to the dealer, get a new oil cooler hose and cut it short by about 5/8 inch where it goes into the block. This will bring the hose in enough to clear the header.
I did this, but I had EM headers. Maybe it will work for you.
Old Feb 8, 2008 | 10:23 PM
JLeatherman
I'm not running the elites. I've got SLP Tri-Ys now. Mine actually hit the adapter itself. However, mine's an 84 which pipes the oil to the radiator (like old-school oil coolers) not coolant to the oil.
Old Feb 9, 2008 | 08:06 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I have them and like what I got, for the dollars I spent.
I had to move a wire bundle (pass side) to the other side of fuel line. Fortunately it was an easy job, both fuel lines separate(filter+union) at that area.
Old Feb 9, 2008 | 11:28 PM
5speedC4's Avatar
5speedC4
My corvette is a 1988 with the Z52 package, so it does have the oil cooler.
Old Feb 10, 2008 | 07:17 AM
AGENT 86's Avatar
AGENT 86
For what it's worth, I have the factory oil cooler and it's not an issue with my Elites.
Old Feb 10, 2008 | 12:01 PM
UnderPar's Avatar
UnderPar
I have had them on mine now for 4 years without any problems. No leaking, no fitment issues, no discoloration, coating is still in great shape. Just have a bung welded on and you'll be good to go.
Old Feb 11, 2008 | 07:29 PM
87vetter's Avatar
87vetter
Default Would be nice if they were tuned
It would be nice if they were tuned for a full improvement like the hooker headers.
Old Feb 11, 2008 | 07:39 PM
CFI-EFI's Avatar
CFI-EFI
You will get a fuller improvement with the 1 5/8" primary tubes of the Hedmans over the 1 3/4" primaries of the Hookers. The Hookers aren't "equal length" headers, either. The Hedman's will start working at lower rpms than the Hookers and pull all the way up top, with the Hookers. The Hedman Elites are probably the best L98 header for the buck.
RACE ON!!!
Old Feb 11, 2008 | 08:20 PM
countylawdog's Avatar
countylawdog
I have the Hedman Elites on mine, bought new 3 years ago ..... very pleased with them.
If the ones you are buying are used, not knowing the outer condition - I would consider having them JET-Hot prior to installation ..... about $200 and they will look like new and have a good coating on them.
Old Feb 11, 2008 | 10:27 PM
Curveit's Avatar
Curveit
... with the last two posts
Old Feb 12, 2008 | 09:50 AM
cmcbunch's Avatar
cmcbunch
yup got the elites on mine too. The primaries on the hookers are way to large for a tpi engine. Didnt have to move the oil cooler line on mine, did have to move a wire bundle. They are very tough for headers. Thermal paint has held up well. Best bang for the buck in a low power application.
Old Feb 12, 2008 | 11:36 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
On mine too, best bang out there for L98
Old Feb 12, 2008 | 11:46 AM
Red Tornado's Avatar
Red Tornado
RACE ON!!!
if i were to do it over, i would have gone with 1 5/8". this was 3 years ago.
my fault for going the advice of others here at the time, due to my own ignorance and thus incompetence.
there's tons of awful advice posted right here on C4 tech all the time.
Old Feb 12, 2008 | 11:56 AM
88BlackZ-51's Avatar
88BlackZ-51
I am very happy with my 1 3/4 Hooker's. They seemed to work well with my stock L-98, and I am sure the new 421 will like them alot better then the smaller Hedman's.
Not too mention the fit and finish on the Hooker's were top notch!
To Headman Elite Headers.....Opinions?
Old Feb 12, 2008 | 01:46 PM
Aurora40's Avatar
Aurora40
Probably because you live in Canada, so they can take advantage of the "free" healthcare.
Old Feb 13, 2008 | 09:31 AM
Aaron's 87's Avatar
Aaron's 87
Be sure to measure the Hedman Exhaust ports and your head ports. The Elites I got were 1.20" side to side, which is smaller than my exhaust ports.
Old Feb 13, 2008 | 11:52 AM
Red Tornado
the uber-socialist state
