EGR Valve
Old Feb 9, 2008 | 03:42 PM
hman1987's Avatar
hman1987
Default EGR Valve
Ok as part of tracing my rough idle problem, I wanted to test the EGR valve. I applied vacumn from the manifold direct and did not notice any movement. Lack of vacumn did not produce any movement. Should I consider this a failure?
Old Feb 9, 2008 | 04:36 PM
rodneyiii's Avatar
rodneyiii
Cruising
What year car and engine do you have? Was the engine running when you did the test? If so, the EGR valve is a negative backpressure type and will bleed off the vacuum applied to the port during low exhaust pressure. You will need a vacuum pump to apply vacuum to the EGR port with the engine off. If its good, the diaphram should move and hold vacuum. As soon as you start the car, the vacuum will immediately bleed off and close the EGR valve.
Old Feb 9, 2008 | 09:29 PM
hman1987's Avatar
hman1987
Default Problem solved
I tested it and it was stuck. She is running fine again. Thanks for the input.
To EGR Valve
