my 89 has electrical issue please help
Old Feb 9, 2008 | 06:50 PM
BE8UP's Avatar
BE8UP
Navigator
Default my 89 has electrical issue please help
last year my 89 did this to me and i went out to start it and my inside lights came on as normal but to turn the key there was nothing no click nothing to the starter... I came back to it about an hour later and it started right up... It has started fine every day for a year now the other day i went out from work??? same issue and i have tried everything from replacing the ignition module on the column ..Is this something in the security system?? What should I try next
Old Feb 9, 2008 | 08:13 PM
93cruiser's Avatar
93cruiser
Does your key have the security chip? My 93 does and I have the exact same problem. The last two times that it happened to me I could start it 30 minutes later.
93cruiser
Old Feb 9, 2008 | 09:08 PM
Happydad's Avatar
Happydad
When I first got mine it did that alot and I found it was a loose ground bundle on the Trans...
Old Feb 9, 2008 | 09:46 PM
chuck13's Avatar
chuck13
yeah,sounds alot like mine when the VATS went screwy.search the forum for some good advice on how to deal with it.i just completely bypassed mine.
Old Feb 9, 2008 | 09:47 PM
RRT vette's Avatar
RRT vette
Sounds like a VATS problem.
http://www.vatssucks.com/
Old Feb 10, 2008 | 10:24 AM
tgtexas02's Avatar
tgtexas02
May not be problem but if an automatic try jiggling the shifter just in case neutral safety switch is bad/little out of adjustment or possibly the clutch neutral switch at very top of pedal assembly. The clutch switch can be very difficult to get out and back in on the manuals. I tested my manual switch by removing the 2-wire connector and put put a small jumper wire across--it would always start in these no start situations. CAUTION: I would never, ever, never use this jumper on a manual wire to bypass for daily operation as the car will start in gear! THAT IS HOW ACCIDENTS HAPPEN!
To my 89 has electrical issue please help
