stalling when cold? LT1 -95
Old Feb 10, 2008 | 06:54 PM
SimonEurope's Avatar
SimonEurope
Default stalling when cold? LT1 -95
Lt1 -95
what could it be?
When the car has been parked for some days its hard to start! When it finaly does the idle is very low, sometimes it even stalls, but as soon as the car is varmed up it runs like it should!
How do i check to see if i have any codes? I have a OBD2 scanner could i use that one? Heard that -95 has some hybrid between obd1/obd2!? If my scanner doesnt work how do i hotwire the thing for codes?
Old Feb 10, 2008 | 07:24 PM
STL94LT1's Avatar
STL94LT1
Do a fuel pressure leak down test, could be a fuel pressure regulator or the check valve in the fuel pump.
Your 95 PCM is OBDI, with an OBDII ALDL.
Old Feb 10, 2008 | 07:26 PM
SimonEurope
Hi and thanks for the suggestion,
Shouldnt the car run bad all the time with a faulty fuel pressure regulator/check valve? Its only when the car is cold.. ??
Can i use my OBD2 scanner anyway? sorry im a newbie :-)
/Simon
Old Feb 10, 2008 | 07:31 PM
STL94LT1's Avatar
STL94LT1
No, you can't use an OBDII scanner.
Here's a thread on the paper-clip method of pulling codes.
http://forums.corvetteforum.com/show...ght=obdI+codes
Old Feb 10, 2008 | 07:54 PM
SimonEurope
Thanks!
Old Feb 11, 2008 | 01:39 PM
SimonEurope
the car only stalls when it hasnt been driven for some days...
Old Feb 11, 2008 | 02:01 PM
etteroc27's Avatar
etteroc27
My obdII will scan the codes on my 95 very nicely. It also monitors the engine as it's running. If yours will plug into the receptacle it will probably work. My chevy dealer told me that 95's came both ways. If the receptacle fits up to the scanner, it will probably work. My scanner works on my 97 pickup and my 95 corvette.
Try it and see.
Old Feb 11, 2008 | 04:57 PM
SimonEurope
i tried it 30 min ago, but its saying linking Error
i did it manual instead
I got no codes stored in CCM, but i had 3 codes in the PCM module (4)
H78
H14
H15
wounder what that is?
Someone know?
Old Feb 11, 2008 | 10:46 PM
LT1CDNRICK's Avatar
LT1CDNRICK
its sounds like your iac idle air control motor is not working or it may be stuck.
Try removing it and cleaning the carbon off and also clean the intake were it sits in.
Also try cleaning the throttle plates.
Rick
To stalling when cold? LT1 -95
