Installing valve springs
Old Feb 10, 2008 | 07:34 PM
PAINTER MAN's Avatar
PAINTER MAN
Default Installing valve springs
I am going to install LT4 valve springs in my 86. I read the FSM today and it shows dampers in the existing springs. The new springs I got did not come with dampers. Do I need to use them with the new springs?
Old Feb 10, 2008 | 10:33 PM
shotchkiss's Avatar
shotchkiss
No, the LT4 springs don't use them.
Old Feb 11, 2008 | 12:43 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Are these going onto 128 heads ??
Old Feb 11, 2008 | 06:43 AM
PAINTER MAN
Yes they are going into 128 heads. Is that a problem?
Old Feb 11, 2008 | 07:05 AM
rodj's Avatar
rodj
Need to check the installed heights.
From memory, the 128 exhaust seat is thicker than the intake so you need to pack the spring up to get the required height
Strick's Avatar
Strick
Are you talking about these?:
If so, no, don't use them as they will change the spring height.
Old Feb 11, 2008 | 07:15 AM
PAINTER MAN
I also have the LT4 retainers, If that makes a difference.
Old Feb 11, 2008 | 08:15 AM
AGENT 86's Avatar
AGENT 86
You will need the LT4 base and caps. Removing the exhaust rotator requires a substantial amount of shims to get the correct installed height on the LT4 springs.
Here was my solution to the problem. I use the factory base and trim the LT4 base to slide over it. In between the 2 bases, I stacked the required shims to get to the correct installed height. This made for a solid platform considering all the shims required on the exhaust side. The intake side, I did the same but only required 1 shim in between the 2 bases.
I used a tappered stone to enlarge the LT4 base. The tappered stone worked well as it removed material equally as it made the hole bigger.
Here are a few pics to help you get an idea.
128 base and the LT4 base
Enlarged LT4 base and virgin LT4 base
The 128 base/shims/LT4 base.
Old Feb 12, 2008 | 06:48 AM
PAINTER MAN
Thanks for the info guys.
Old Feb 13, 2008 | 12:06 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default heads
I just had my spring pockets machined so they were the same heights
To Installing valve springs
