New Cam For The LT4
Old Feb 11, 2008 | 09:15 AM
NEILZVETTE's Avatar
NEILZVETTE
Default New Cam For The LT4
So I sold my 85 Vette and have a few dollars laying about and want to get the performance level of my LT4 up to the standads of the C5/6 level. I am shooting for 4:10 gears and a camshaft swap. I know the HotCam is a popular swap but are there better choices out there. I know I went from a older hyd. cam to a newer Xtrem Enery cam,both flat tappet with similar lift #'s in a Camaro, and it was very noticable. This car is not a daily driver but it does see alot of use so I need to keep mileage and manners in mind..no radical cam suggestions please. Also will I need to make a valave spring change as I already have LT4 springs?
Old Feb 11, 2008 | 10:22 AM
93Blackrose's Avatar
93Blackrose
I had the Hot Cam but switched it out to the Lingenfelter 211/219. I like the Lingenfelter cam much better.
Old Feb 11, 2008 | 11:41 AM
GS348's Avatar
GS348
Old Feb 11, 2008 | 11:51 AM
C4DC's Avatar
C4DC
St. Jude Donor '06
I've been wanting to do the CC503 when the stars align. Just a step up from the HC. Gets to be like a bag of worms with all the parts that you can or need to replace when doing this job.
Old Feb 11, 2008 | 11:56 AM
StealthLT4's Avatar
StealthLT4
I've been wondering this as well. I'm planning on camming my LT4 this summer, and am thinking something slighty more radical than the Hot Cam, but I'm not really sure what's out there...
Old Feb 11, 2008 | 12:18 PM
Digital Disaster's Avatar
Digital Disaster
I've been wanting to upgrade and here's what I've decided on:
(at .050) 23x/24x duration, 520 + lift, 112 seperation
I've got a 383 and 4.09 gears.
Old Feb 11, 2008 | 12:55 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
CC503 will work well. A bit more lift than the Hotcam.
Old Feb 11, 2008 | 05:57 PM
WickedVetteLT4's Avatar
WickedVetteLT4
What about just putting some 1.7 rockers on the hotcam for more lift??
Old Feb 11, 2008 | 08:42 PM
BADDUCK's Avatar
BADDUCK
Why go to the extra expense, he already has 1.6's. I think you can find a CC503 for around $250.
Old Feb 11, 2008 | 09:16 PM
StealthLT4's Avatar
StealthLT4
http://store.summitracing.com/partde...8&autoview=sku
I'm liking the 503. $30 more than the hotcam, and a tad more duration. Same overlap though (112*), so the lope shouldn't be much worse. I think I'm sold!
My only question; it lists the basic operating range as 1800 - 5800...would this still be fine in an LT4 revving to 6300?
Old Feb 11, 2008 | 11:47 PM
383_Proof's Avatar
383_Proof
good write up.....
http://ls1tech.com/forums/showthread.php?t=836200
Old Feb 12, 2008 | 09:43 AM
pr0zac's Avatar
pr0zac
you can NOT use the lt4 springs for much much else than a hot cam or a zz4 or stock. i threw a ligenfelter 216(213/219 .492/.502) in my lt4 and it would float the valves and that was with new springs.. you certainly wouldn't be able to go bigger.
Old Feb 12, 2008 | 10:19 AM
BADDUCK's Avatar
BADDUCK
too much lift for stock springs.
Old Feb 12, 2008 | 11:51 AM
jonecap's Avatar
jonecap
I can't speak for the other cams, but my car runs like a raped ape with the hotcam and still has good drivability with a bit of lope at idle. I'm sure it would make more power with a bigger cam, but it depends on how you're going to use the car.
Old Feb 12, 2008 | 02:18 PM
WickedVetteLT4
Im now considering this cam myself.
Hate to thread jack but im about to have my LT4 heads and intake ported and prob ditch the hotcam (although i love it now) for something a little bigger.
How does this cam perform compared to the Hotcam?
The answer will prob be useful to the post owner anyhow...
Old Feb 12, 2008 | 02:59 PM
all4c4lt4's Avatar
all4c4lt4
Why not a custom grind cam? Several LT4 owners have had great results with a custom grind or a cam bigger than the even the 503 (Zix, LT4POWR, etc.)
Old Feb 12, 2008 | 03:58 PM
WickedVetteLT4
Thats def something to consider. I would have no idea what specs i would need to go with though. I am very pleased with my hotcam right now but when i pull the heads and intake off to be ported, im thinking i might as well step it up at the same time.
To New Cam For The LT4
Old Feb 13, 2008 | 01:19 AM
Curveit's Avatar
Curveit
The duration numbers look ok but the lift is way down. You should be able to get lobes from Comp Cams closer to .600" lift with those duration numbers, and 1.6 rockers. Springs would have to be changed but that's not a bad idea anyway, along with valve seals, if the motor has some miles on it. That would be about the right shift point, 500-1000 RPM over HP peak.
Old Feb 13, 2008 | 11:23 AM
rklessdriver's Avatar
rklessdriver
That lift is quoted with 1.5 rockers. The CC 503 has a .335 intake lobe and .340 exhaust lobe.
With 1.6 rockers it would be .536/.544 lift.
You still should get better springs as the LT4 springs are good to about .550 lift but your maxing them out on a CC503.
Will
Old Feb 13, 2008 | 01:31 PM
WickedVetteLT4
My car already has aftermarket springs i believe from when the previous owner put the hotcam in it.
