I just bought an lt4 hotcam for my 96 ce lt4 vette. My questions are :
1. About how long will it take me to put it in?
2. About how much power am i looking to gain? I already have EM LT's, bullet cats, slp claw intake, slp 3" cat-back.
3. Is it something I should attempt myself, I have the fsm's and have done the LT's and waterpump myself which wasnt hard, just time consuming.
4. Do I have to break open the a/c lines to pull the cam out and replace?
5. Finally, (I have read that I could, but wanted to cinfirm) can I keep everything else stock (rockers...)?
1) Depends on the tools you have and your mechanical abilities. Some can do it in a day and a half, some take weeks
2) ~30rwhp (on a Dynojet dyno)
3) Only you know that. For some, cam swaps are a walk in the park, for others it's like learning Quantum Physics
4) No
5) You can although most don't because they want the adjustability
1. It took me weeks (just to get the hub off).
2. I'm guessing 25-30.
3. It is easier on the 95s and 96s; you should be good.
4. No.
5. Yes, but replace the valve stem seals anyway--they're cheap.
Am i correct in assuming the lt1 program is used in the lt4's? By "wouldnt run long" are you saying that it would be non drivable?
LT4s have their own programming, specific to the LT4 engine. While similar to the LT1, it is not the same. Timing tables, fuel enrichment, closed throttle spark advance, injector constant (to name a few things), etc are different.
The commonly used tuning package is "LT1 Edit" for OBD II, but it's for both engines. It's a GUI that you use to download and upload PCM flash files. Tunercat also has an OBD II tuning program. These are real tuning programs not some flash in a can like Hypertech. You inadvertantly screw up the tune and upload it into your PCM, you risk destroying the engine. There are no safety nets.
People have run for years on the stock LT4 programming. The SES light is an annoyance (and will result in a failed emissions test if you have that in your state), the exhaust will smell bad when you first start the car, and after doing all that work it seems a waste to leave easy hp "on the table" so to speak.
