HELP!! The dash is crazy!
The Flame out that you describe leads me to believe that it is not the gage cluster but something else like what kmiller posted.
believe me when I tell you, Batees sight will help you fix the cluster all on your own. But I'd make sure it is cluster related or else it'll be a Cluster @#$%#
when cold, everything normal. when it got to about 120 degrees water temp, the dash started the symptoms............
it would dim, then go bright, all the readouts go to zero, the engine RPM at idle went to 1200 RPM, then the computer made all the digits go to 888 in each catagory, then the idle would fall back to normal, the mileage readout would go back to reset, then the mileage counted like normal in instant and average, the volts started like at 14.8, and then trickled down to 13.8, and it ran fine ................until I let it get cold, and then it started all over again till the temp got to 120, then it went bizzaro, then the computer got warm, then fine. It seemed to last about 4-6 minutes depending on the outside temp.
Chris
Sometimes, even now, the dash goes dark, and theturn signal indicator arrows both come on, the blue high beam light goes on, and If I tap the dash near the headlight switch, it alll comes back. I suspect a poor ground in that area.........oh, mine's an 86 as well. build date: 9-85 so early early.
