A light intermittent knocking sound ???????????
Old Feb 14, 2008 | 09:33 PM
Tflow's Avatar
Tflow
7th Gear
Default A light intermittent knocking sound ???????????
I have a light knocking sound from the bottom side of engine area on a 1990 Vette. The sound only occurs after the engine fully warm up and only gets a little louder when the A/C is on . You have to pay attention in order to hear the light knock. The car drives and shifts fine with no problems. I brought to 2 mechanics and got 2 different opinions . One said is from the clutch bell housing and the clutch needs replacing. 2nd mechanic said it is the main bearings being worn and the crankshaft having too much play. I was wondering if anybody else has this problem or have an idea what's really the problem here. Let know me what you think.
Old Feb 14, 2008 | 11:20 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default knocking
check your harmonic balancer. It could be coming loose and tapping the timing cover.......mine did
Old Feb 14, 2008 | 11:23 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
I'm assuming you have a ZF 6spd. It's common for the dual mass flywheel to break down and cause that noise (ZF6's use a special dual mass flywheel because they tend to rattle). Or possibly someone has changed the dual mass flywheel out for an aluminum one. You might try searching for previous posts on this problem. It also could be your bearings, but generally that would be a rod bearing.
To A light intermittent knocking sound ???????????
