LT4 crankshaft ?
Old Feb 15, 2008 | 10:30 AM
GS023's Avatar
GS023
Default LT4 crankshaft ?
Does anyone know if a stock LT4 crankshaft has a key slot milled in to it? I know the hub is not keyed but have heard the crank does have a slot machined in to it. Looking at installing an ATI super damper. Any help would be apreciated.
Old Feb 15, 2008 | 10:44 AM
Mojave's Avatar
Mojave
Yes, it does have a keyway, and there is a key installed. The key is weird, though, as it sits flush with the crank except for at the very back, where it sticks up for the tone ring for the crank position sensor (OBDII only).
Old Feb 15, 2008 | 11:34 AM
GS023's Avatar
GS023
Thanks.
Old Feb 15, 2008 | 04:45 PM
Zix's Avatar
Zix
The crank has two key-ways cut into it, one for the timing gear and crank position sensor, and one for the crank hub. There is a key installed for the timing gear and CPS, but there is no provision for a key machined into the stock crank hub.
Old Feb 15, 2008 | 04:49 PM
GS023's Avatar
GS023
My plan is to install an ATI underdrive balancer and they are keyed. Just did not want to pull the crank to have machined.
Old May 7, 2008 | 11:48 PM
Positive Pressure's Avatar
Positive Pressure
So when installing the ATI I assume you need to make a key to seat the factory crank key slot to the ati key slot? If so any idea what size?
Old May 8, 2008 | 05:24 AM
GS023's Avatar
GS023
Have not got that far yet. I assume it will be a standard size half moon type key.
Old May 8, 2008 | 09:52 PM
Positive Pressure
Tackled it tonight....3/16 half moon. To put the ATI hub on the engine must be raised or rack and pinion moved
To LT4 crankshaft ?
