Better Header Pictures
Old Dec 4, 2001 | 10:27 AM
Nathan Plemons's Avatar
Nathan Plemons
Default Better Header Pictures
I finally got access to a better digital camera, so here are some pictures of my engine / headers
I'll save bandwidth on the others
http://24.17.202.123/graphics/corvet...e_left_new.jpg http://24.17.202.123/graphics/corvette/header_right.jpg http://24.17.202.123/graphics/corvette/header_left.jpg
Ignore the tie wrap wire looms ;)
Old Dec 4, 2001 | 10:41 AM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
Default Re: Better Header Pictures (Nathan Plemons)
Looks good! Are those ARP header bolts?
Old Dec 4, 2001 | 10:54 AM
GRX's Avatar
GRX
Nice. Do you ever smog test that motor????
Old Dec 4, 2001 | 11:32 AM
Nathan Plemons
Default Re: Better Header Pictures (War Machine)
Yes they are ARP bolts. I thought the 12 point would be really cool, turns out
that they kinda suck. Sure they look cool, but it makes it that much harder to
get a wrench on them since you can't use the open end. If I had to do it again I'd get the stainless ARP hex head instead of the 12 points. If I ever have to take the headers loose I'll do that.
GRX, no I don't have to worry about smog, I can make all I want.
Old Dec 4, 2001 | 11:35 AM
War Machine
:cool: Thanks for the tip! :cheers:
Old Dec 4, 2001 | 08:51 PM
arnold's Avatar
arnold
If you use stainless in aluminum heads they tend to get slippery (loosen up).
They may not stay tight. They may need sealant applied. Or, can anybody
say safety wire time. That can be a pain. :( Just an observation.
Old Dec 4, 2001 | 09:41 PM
ezmoney92's Avatar
ezmoney92
Default Re: Better Header Pictures (arnold)
Go with Stage 8 locking header bolts, 1/4" longer then the stock bolts in stainless and you'll have no problems. ( They also look :cool: ) :seeya
Old Dec 4, 2001 | 11:00 PM
95BLKVette's Avatar
95BLKVette
Default Re: Better Header Pictures (ezmoney92)
From Experience.......:rolleyes:
Make sure your plug wires stay well clear of those nice new headers or you'll soon find out how toasty they will get :crazy:
It looks like some of yours are resting directly on the header pipes...hopefully it's just the camera angle :D
Old Dec 4, 2001 | 11:01 PM
John G 92's Avatar
John G 92
Looks nice was wondering were you got them and if you would like to tell how much? did it all bolt in or was it made to fit?
Old Dec 5, 2001 | 12:38 AM
VMAX451's Avatar
VMAX451
:yesnod: Put some anti-seize on Stage 8 lockers and forget them, they won't come loose. You want to minimize dealing with the ones by cyls 7 and 8 at all costs!
Old Dec 5, 2001 | 08:38 AM
BrentDev's Avatar
BrentDev
Nathan - what are you dressing your fuel rail covers with? Just curious!
Thanks.
Old Dec 5, 2001 | 11:05 AM
Nathan Plemons
Default Re: Better Header Pictures (John G 92)
I got them through Chris at Speed Demon, they are actually headers for the L98 so you will need some fabrication done with the rest of your exhaust work. All said and done it was around $600 but I'm pretty sure he told me they were on sale, that's why I ordered them when I did. Regardless he'll work with you go get a good price, they are a good company to work with.
For the fuel rail covers and everything else black I used this CD-2 engine detailer spray I bought from AutoZone. I use it on the insides of my fenders (the parts on the hood) so they clean off easier. I don't remember how much it costs but I'm fairly pleased with the results. I just picked it up one day as I was browsing through the store, thought I would give it a shot.
There aren't any plug wires on the headers or they would be toast by now. I've seen that too many times, that's why I've got tie wraps everywhere. I don't have any decent wire looms yet so I tie wraps will just have to do. Plug wires are such a PITA I want to make sure I don't burn any. I agree the camera angle can make it look kinda bad but I assure you they are all in the clear.
Old Dec 5, 2001 | 12:11 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
On the driver's side, I notice your engine does not have 3 brackets that I have on my 1996. There is a bracket that bolts to the intake and to the back of the alternator and A/C compressor. There are two rod braces that attach to the 2nd and 3rd header bolts that run up to the back of the alternator and AC compressor. Did you remove them or were they never there?
[Modified by Mez, 10:25 AM 12/5/2001]
Old Dec 5, 2001 | 01:39 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Default Re: Better Header Pictures (Mez)
Most of the time, these brackets do not get put back on and you WILL get a vibration from the AC when you use it. I have heard you can not put them back on with long tubes. I will find out first hand if I ever get my engine back.
Old Dec 5, 2001 | 03:04 PM
Nathan Plemons
The thing with the brackets is that some of them bolted to the stock manifolds which are much thicker than the headers. The result is that there is no place to put them back. All of the accessories are mounted SOLID to the accessory bracket. I can't say about vibration because I have not re-filled my A/C system yet. I guess it's all in the price you pay for performance.
To Better Header Pictures
