OK, need some help
Old Feb 17, 2008 | 12:23 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Default OK, need some help
So I have everything set up and the motor running.
Problem is it's not running the way I want it to be running.
I suspect I may some timing/ignition issues.
Here's what's happening:
1. I have what I think is a knocking. Never heard one before. I'm running premium gas.
2. The #8 cyl header pipe is getting red hot
3.idle goes up and down. funny part is it did that before I did the work. it kinda hunts for idle. IAC is new.
4. There's a hesitation when I hit the throttle. It will kinda bog before it goes..
I'm getting no codes.
Old Feb 17, 2008 | 12:34 PM
_twisted_'s Avatar
_twisted_
advance the timing and monitor the headers, check the timing.
the IAC ECM is going to need to learn somewhat, also check for air leaks
the bog could be cleared up with timing.
Old Feb 17, 2008 | 12:35 PM
_twisted_'s Avatar
_twisted_
did you do the proper set up of the IAC? to set the min idle?
Old Feb 17, 2008 | 12:36 PM
jsup's Avatar
jsup
no. i have the fsm. i will read how to do that. Suggestions on timing?
Old Feb 17, 2008 | 12:47 PM
_twisted_'s Avatar
_twisted_
go to the tech tips section and download the instructions for the IAC setup. keep it handy so you follow it properly.
set your min idle almost on your target with the iac, down only like 50-100 rpms. the iac is slow and will hunt if your not tight with the range.
you hve a modified set up now, the fsm should only be a reference.
Timing is going to be something your going to have to play with to get it right. DOing adjustments to the timing may also require reseting the IAC along the way.
SOme of the aftermarket throttle bodies make setting the IAC a PIA, that is why I say to set it up the min idle tight to the target.
Old Feb 17, 2008 | 12:53 PM
jsup's Avatar
jsup
The TB is stock.
Isn't the idle RPM set in the chip?
Old Feb 17, 2008 | 01:11 PM
_twisted_'s Avatar
_twisted_
Originally Posted by jsup
The TB is stock.
target idle is, you need to set up the min idle -the farther off you are on the min the more the idle will hunt - the iac is a stepping motor, it is slow a snail **** it will over shot and then over compensate the other way.
Old Feb 17, 2008 | 02:13 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
1 & 2: Timing is the likely culprit. We got it close, but not dead on because we were not able to get it to idle with the ESC wire disconnected (sorry I had to leave!!). Min idle definitely needs to be set first, so start there.
3. Again - start with setting the min idle (which should be set about 75-100 rpms below the programmed idle in the chip. Ask Alvin where it is set.
4. Probably a combination of timing and acceleration enrichment, but again - min idle needs to be set, then timing, then see if there is still a bog.
Old Feb 17, 2008 | 07:10 PM
staugur's Avatar
staugur
I think a timing/ignition issue would be global and not just on #8.I would be looking at either a valve gap issue or a bad injector.#8 should be the coolest running of the lot if you still have the EGR setup.Also there's a possibility that you have the plug wires hooked up wrong(forgive me)With a bad idle it's hard to tell and will give you a cherry red pipe and the rest of your symptoms.
Old Feb 17, 2008 | 09:13 PM
jsup's Avatar
jsup
HEY!!! Went over everything and found we had 4 and 6 switched on the distributor. Clearly it was on your side of the motor..... I don't make those mistakes.
Can't fire it up an 9:15 at night. Neighbors would be pissed.
I'll try it tomorrow.
That right there will be a start. The fact that it was running at all is a good sign for tomorrow.
Old Feb 17, 2008 | 10:18 PM
staugur's Avatar
staugur
What can i say!
Old Feb 17, 2008 | 10:22 PM
jsup's Avatar
jsup
Originally Posted by staugur
What can i say!
What do you mean by valve gap?
Old Feb 17, 2008 | 10:50 PM
Red Tornado's Avatar
Red Tornado
jsup, have you talked to alvin about getting him those 2 datamster recordings we discussed? this will be your next order of business.
oh, and in 50 miles you'll want to change your oil. then do it again at 500, then again at 1,000. change your oil filter each time as well. then back to your normal change intervals.
Old Feb 17, 2008 | 10:52 PM
jsup's Avatar
jsup
ByeByeL98 has datalog capabilities. After I get it running right, and get the exhaust on there, we'll do a datalog and see where that goes.
I am going to do that with the oil. Cheap insurance.
Old Feb 17, 2008 | 11:01 PM
Red Tornado
great
Old Feb 17, 2008 | 11:02 PM
jsup's Avatar
jsup
great
Data logs before the exhaust aren't going to be right, we can't be sure we go into closed loop. (just learned that one)
Old Feb 18, 2008 | 12:20 PM
byebyeL98's Avatar
byebyeL98
HEY!!! Went over everything and found we had 4 and 6 switched on the distributor. Clearly it was on your side of the motor..... I don't make those mistakes. Can't fire it up an 9:15 at night. Neighbors would be pissed.
See my other post where I clearly deflected blame
Glad to hear all is well. Get some exhaust on it and get ready to head on up in a few weeks.
Old Feb 18, 2008 | 12:27 PM
jsup's Avatar
jsup
Will do. Hey what's that, is that the sun? Maybe I can go around the bolck!!!
To OK, need some help
