drained battery
Old Feb 22, 2008 | 08:30 PM
lil_Mike's Avatar
lil_Mike
ok well hooked up my meter and was watching it drop and then un plugged the alternator cable and no more draw. so i gotta replace the alternator.
also hooked up my kill switch thing. ill try to get some pics
Old Feb 27, 2008 | 03:13 PM
lil_Mike's Avatar
lil_Mike
ok replaced the alternator and it looked fine drove it for a day or two and then now i go to get in my car and the battery is dead yet again. my stereo shop guy said that there was 2 accesory wires under my dash and one was getting constant power. that might be the drain there. if i cant fix this soon im about to take it to the dealership and i dont want to.
Old Feb 27, 2008 | 03:36 PM
MK 82's Avatar
MK 82
Originally Posted by RPD_Vette84
im having about the same problem. i can jump start the car fine and itll run. i hooked up a volt meter after i turned it off and immediately it starting dropping voltage. when the car is running ive seen voltage from 12.9 to 13.6ish or so. voltage at batt was 12.9 with car off. ive tried a couple different batteries (friends had some) and read through the FSM and still kidna lost. i am wondering because in the FSM it says check belt tension and since i put my headers on i lost the brackets on the back side of the alternator. would that cause a loose belt?
sorry for the thread jack i didnt want to start a new post if i have about the same problem.
GROSS HIJACK!! Don't steal the man's thread.
Old Feb 28, 2008 | 05:49 PM
myVETTEmyDREAM's Avatar
myVETTEmyDREAM
I am having the same issues in my 86. My mechanic traced it to the gauge cluster.
Old Feb 28, 2008 | 05:58 PM
Overboost's Avatar
Overboost
From: Flint Michigan, #2 in unemployment, #3 in Violent crimes
I had this problem a few years back and it ended up being a combination of two things.
1: bad voltage regulator for the battery. yours is internal so that is probly why it worked for a bit when you changed the alternator.
2: bad ground between the engine and body and battery NEG cable (secondary, small one) and the body
Old Feb 28, 2008 | 07:47 PM
lil_Mike's Avatar
lil_Mike
well i had a cheap battery in there and i checked it and pretty much all 6 cells were dead. so i replaced it with a interstate one and it seems to be workign fine.
Old Feb 29, 2008 | 02:53 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
You might want to repeat jfb's procedure again.
A fresh alt and batt can easily disguise a leak until the batt runs down again.
Nice write up JFB
