electrical issue, engine code 42
Old Feb 17, 2008 | 05:15 PM
CrippleDave's Avatar
CrippleDave
Default electrical issue, engine code 42
ok so i had some electrical issues with my 89 vette. The engine code i keep getting now is 42. The info i got on this says that i should Check wiring at ignition module. Replace ignition module. Possible ECM failure. How would i do this???? what is the ignition module and how would i know it is this or the ecm? thank you for yor time
Old Feb 17, 2008 | 08:18 PM
CFI-EFI's Avatar
CFI-EFI
Start by following the trouble shooting charts in your FSM. It should lead you to the failed (?) item by diagnostic testing. It can also help you locate what to test.
RACE ON!!!
Old Feb 17, 2008 | 11:02 PM
Dads90's Avatar
Dads90
Have you played with the timing lately. You have to disconnect the EST wire to bypass the computer. That usually throws a code. Unless its loose, locate it and check connection. See picture below the EST wire located on the batch of wires going to ECM.
To electrical issue, engine code 42
