speed sensor for 6 speed conversion
Old Feb 18, 2008 | 03:48 PM
Tom Urani's Avatar
Tom Urani
Default speed sensor for 6 speed conversion
I've just completed a 6 speed conversion on my 1986 Corvette. The speedometer is registering speeds slower than I'm actually travelling. Is there a speed sensor available to remedy this problem? The transmission is from a circa 1990 car. Thanks
Old Feb 18, 2008 | 04:55 PM
CFI-EFI's Avatar
CFI-EFI
It isn't the VSS (Vehicle Speed Sensor) causing the problems. It is the speedometer gears. Apparently the donor car and your car had different rear axle ratios. If you use both the drive gear, and the driven gear, along with the VSS from your '86, the speedometer will read correctly. My guess is that the "new" trans has a grey 15 tooth drive gear and that the old trans had the red 17 tooth drive gear.
RACE ON!!!
