Compression Ratio Question.......
Old Feb 26, 2008 | 04:16 PM
  #81
mseven's Avatar
mseven
Originally Posted by hooblyboobly
I think that now is the time to learn what the old schoolers know and at least engage in an intelligent conversation with them without straining my brain like I'm trying to understand a West German dialect.
I admit that I am impressed with this statement, as it sounds as though you are coming to age.
Old Feb 27, 2008 | 04:23 PM
  #82
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by anesthes
So here it is one time. The factory calibrations run around 22 degrees of total advance at 220f. If you can run a lower thermostat, and turn the fans on cooler to keep the car between 180-190f, you can then run around 32-34 degrees of total adance. "the more spark advance, the more power it will make" until you reach detonation. Some motors like more, some like less.
-- Joe
Unfortunately, you're talking about one specific engine; yours. Or even a few; the later computer controlled F-bods and 'Vette's you've had. You DON'T know what all CFI has done (or anyone else on this board), but I bet that the '84 'Vette isn't his first car. I've had (two) engines that started losing power by advancing timing, BEFORE they started pinging/detonating. So CFI is technically right, that the statement, "The more spark you can run, the more power you can make" isn't a universally correct statement.
I think that YOU are right, that in the cars you've played with, cooler temps can allow more advance (by virtue of the programming GM put into the PCM), and in those particular engines, they can then make more power too. But the statement you made isn't correct as a blanket statement, and if you stand behind it unequivocally, you'd be wrong.
Old Feb 28, 2008 | 01:41 AM
  #83
Curveit's Avatar
Curveit
The man has much knowledge about C4s, and is a major asset to the Forum... Y'all should "relax" a bit. It's called "dry humor"; look for the humor in it. I guess you either you get it, or you don't. Cracks me up.
Old Feb 28, 2008 | 02:39 AM
  #84
Curveit's Avatar
Curveit
Some people just have no idea how obvious it is; when someone really doesn't know motors, to someone who does. CFI-EFI does.
Old Feb 28, 2008 | 06:24 AM
  #85
aboatguy's Avatar
aboatguy
This thread degenerated into a feud .....
I'm on a FOB in IRAQ with crappy connectivity and this thread is turning/has turned into a waste of bandwidth
Old Feb 28, 2008 | 07:10 AM
  #86
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Those with deleted posts better take heed of the rules............no attacks or thread hijacks. Get back on topic or get out of this thread.......Best if you follow the rules and let us moderate others........no ones language and personal attacks will be tolerated period. Notify us of bad posts, when you reply in a poor tone you are just as guilty as the OP. Attack Ideas if you must but not people…If ya got questions about moderation, PM or e-mail them…….also a rule.
Old Feb 28, 2008 | 06:51 PM
  #87
fnsblum's Avatar
fnsblum
Ditto aboatguy & Curviet. Later! Frank
