Compression Ratio Question.......
Old Feb 19, 2008 | 09:41 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Default Compression Ratio Question.......
Ok, last annoying question as to my build.......
The stock CR was 10.25:1. The only thing I changed was the gasket. I went from .050 to .040. What is my CR now.
I know that there are CR calculators out there. I don't have all the info such as deck height, which would be stock, and piston volume, again, stock.....
Any help would be appreciated. Anyone think I picked up 1/4 point? 1/2?
Old Feb 19, 2008 | 09:49 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
I don't know but it wouldn't be much. Can you use one of those calculators to model a baseline that is close, and then just change the gasket variable? That should give you some idea. My guess maybe .25:1
Old Feb 19, 2008 | 10:16 PM
mgbss's Avatar
mgbss
JSUP
I was just working on this last night, I will try to look it up for you but I think it is less than .25, I will guess about an .125
Joe
Old Feb 19, 2008 | 10:21 PM
jsup's Avatar
jsup
Originally Posted by mgbss
JSUP
Joe
I used an online calculator and just minipulated some of the numbers and came up with 10.5.
I left the chamber size and such the same, just manipulated the deck clearance and piston volume until I hit 10.25, or close enough to it. Then I changed the gasket.
I don't think that's all that accurate.
Old Feb 19, 2008 | 10:28 PM
1990dtgL98's Avatar
1990dtgL98
St. Jude Donor '10-'11-'12-'13-'14
What gasket?
Becuase its not just the compressed thickness...but also the bore.
I know my 1010 gaskets are .039 thickness...but also 4.166 bore. Stockers are something like .051 compressed with a 4.06 bore.
That bore will also affect volume for the calculators
Old Feb 19, 2008 | 10:31 PM
BADDUCK's Avatar
BADDUCK
That's what I was suggesting. The nice thing is .... the point is moot. It is what it is!
jsup's Avatar
jsup
Originally Posted by 1990dtgL98
What gasket?
Felpro 1010s. So maybe there's no gain, which is cool. I just didn't want to lose anything.
Old Feb 19, 2008 | 10:47 PM
mgbss's Avatar
mgbss
I came up with about a .25 as everybody else did however I had to mess with the numbers to get the stock to 10.25, what is the dish of the stock piston?
Joe
Old Feb 19, 2008 | 11:06 PM
MK 82's Avatar
MK 82
Your stock 1990 L98 short block has a CR of 9.5 to 1.
Old Feb 20, 2008 | 01:04 AM
hexane's Avatar
hexane
No, 90-91 Vettes had 10.25:1 from the factory from the flat top pistons.
Old Feb 20, 2008 | 02:13 AM
aboatguy's Avatar
aboatguy
I'd like to see the specs on this L98.
Old Feb 20, 2008 | 07:09 AM
jsup's Avatar
jsup
It's 10.25. Bet the house on it.
Old Feb 20, 2008 | 08:12 AM
BADDUCK's Avatar
BADDUCK
Yup!
Old Feb 20, 2008 | 12:51 PM
aboatguy's Avatar
aboatguy
Got it didn't disagree just was looking for the specs IE 54cc heads, -5cc pistons, .025 below the deck etc.
I wonder why GM would saddle a high compression engine with such a restrictive intake.
Mike
Old Feb 20, 2008 | 04:51 PM
MK 82's Avatar
MK 82
Anyone have particulars on how this CR increase was achieved. I am just curious as to how.
Old Feb 20, 2008 | 05:02 PM
jsup's Avatar
jsup
Me too..I checked the FSM, it does say 10.25....
Old Feb 20, 2008 | 05:54 PM
MK 82's Avatar
MK 82
What grade fuel did you use in this engine?
To Compression Ratio Question.......
Old Feb 20, 2008 | 05:55 PM
Calderone's Avatar
Calderone
http://www.corvetteactioncenter.com/...0/90specs.html
i wonder why it has more compression but the same torque and hp from the previous year ??????????
http://www.corvetteactioncenter.com/...9/89specs.html
Old Feb 20, 2008 | 06:01 PM
jsup's Avatar
jsup
Always used super. The fuel cap says use only super.
Old Feb 20, 2008 | 06:24 PM
BADDUCK's Avatar
BADDUCK
Flat top pistons.....1989 had dished pistons and 9.5:1
