1:7 Roller Rockers?
Old Feb 20, 2008 | 02:12 PM
NEILZVETTE's Avatar
NEILZVETTE
Default 1:7 Roller Rockers?
Ok I am not going to lie...I don't want to tear into my LT4 with no leaks to do the cam if I can keep away from doing so. Does anyone make a 1:7 rocker arm and what kind of improvements would one expect to see.
Old Feb 20, 2008 | 03:23 PM
95PoloVert's Avatar
95PoloVert
Active Streak: 90 Days
CompCams and Scorpion both make 1.7 ratio narrow-body rockers last I checked.
The CompCams offering is out of their Hi-Tech line and pretty pricey. $425 comes to mind.
Scorpion was around $200-210 a couple of years ago.
I think that they're both NSA, so you'll need hardened pushrods and guideplates. You'll also need new studs, as the LT4 stock studs are 10mm and the aftermarket pieces will be 3/8" or 7/16". (might as well go with 7/16" if you upgrade.)
You already have 1.6 roller rockers, so the benefits won't be as great as the LT1 guys going from a 1.5 ratio stamped steel rocker to a 1.6 roller.
I'd think you'd net somewhere between 5-10hp, but hopefully one of the LT4 guys will have more qualified feedback on this.
Old Feb 20, 2008 | 05:36 PM
rklessdriver's Avatar
rklessdriver
Scorpion.
Still around $200-$225 depending.
95 Polo is correct you will need 7/16 studs, guide plates and hardend pushrods as the rockers are non S/A.
Will
Old Feb 20, 2008 | 07:13 PM
BAM92's Avatar
BAM92
Member Nathanplemons said he got another 15 hp with 1.7's.
Old Feb 20, 2008 | 08:22 PM
NEILZVETTE's Avatar
NEILZVETTE
Looks like I am screwed....to put different studs on I am looking at machine work..IE..pull the heads. I think 4:10's just might have to do this season!
Old Feb 20, 2008 | 08:38 PM
JackDidley's Avatar
JackDidley
What machine work for studs? I am not familliar with LT motors but on a L98, its a bolt in deal.
Old Feb 21, 2008 | 03:12 PM
cmcbunch's Avatar
cmcbunch
Yeah the "machine" work claim is bogus. You just need the right studs. They just bolt in.
Old Feb 21, 2008 | 05:19 PM
hgh pwr's Avatar
hgh pwr
they might need to be drilled and tapped unless the studs are 10mm on one side and 7/16 on the other.
Old Feb 21, 2008 | 05:24 PM
rklessdriver
His heads are tapped 7/16 for the rocker studs.
The factory GM STUDS are 7/16 on the bottom and 10mm on the top.
NEILZVETTE
All you will need is new 1.7 Rockerarms, regular 7/16 Studs, Guide Plates and Hardened Pushrods. It is a bolt on proceedure.
Will
To 1:7 Roller Rockers?
