Quench
Old Feb 20, 2008 | 11:32 PM
mgbss's Avatar
mgbss
Default Quench
Once again my eyes hurt from searches Lots of good reading though (mostly)
Anyway, is anybody running less than .039 quench area ( example: 0 deck with a FelPro 1010) or any other combo, KB pistons suggest .040 for the least some books say as low as .025-.030 Just wondering what some actual engines are running.
Joe
Old Feb 20, 2008 | 11:51 PM
1989TransAm's Avatar
1989TransAm
On my L98 I'm running the pistons .007" down the hole and the GM .028 head gasket. I'm currently shifting at the 6100 mark and with my new cam upping that to 6300rpm. I would not go less than a .035" quench as there is apparently no advantage to it. Most say .035" to .040" is good.
Old Feb 20, 2008 | 11:59 PM
Demonic85's Avatar
Demonic85
Is the 1010 a thinner gasket than the original GM one?
Old Feb 21, 2008 | 06:39 AM
mgbss's Avatar
mgbss
Den9omic85
Yes the 1010 is a .039 Gasket the original at least on some years (I have read, I think Alum Heads 87 up) is.051. My 85 had steal shim type (around .015- .020 I think), but that is the HUGE port 76cc head.
89 TransAm,
Are you running a stock bore or a fresh bore with your .035 quench?
Joe
Old Feb 21, 2008 | 08:53 AM
mseven's Avatar
mseven
I would bet that most would recommend around .038.
Aside from theory, the quench distance should be between about
.037 and .044 (the distance between the cylinder head and the piston deck). If you run less than about .035, and at high rpm levels the pistons might hit the cylinder heads. If you run more than about
.044 thousands the quench effect of forcing the fuel/air mix to the center of the cylinder from the cylinders edge area looses both speed and effectiveness.
Old Feb 21, 2008 | 09:02 AM
anesthes's Avatar
anesthes
Dead on. I usually go .005" in the hole and a felpro-1010 on my builds.
Some guys I know run sub .030", with a high silicoln alloy forging with very low expansion properties and H beam rods. I'm running the same, but I still keep it around .044" because even the slightest bit of expansion at high RPM and you might get a tap. really crappy forgings will expand tons.
-- Joe
Old Feb 21, 2008 | 12:26 PM
1989TransAm
Mgbss; Yes I'm running a fresh .030" bore.
Old Feb 21, 2008 | 05:36 PM
mgbss's Avatar
mgbss
I see some info on Forged Pistons do Hypereutectic Pistons make a difference should more area be left or could they be ran tighter, just trying to learn.
Joe
To Quench
