Pull the antenna jack out of the back of the radio.
..i think he said he doesn't want the antenna to acivate when he turns on the radio.....pulling the antenna from the radio solves nothing and will only prevent reception of radio signals.....
Is there an easy way to disable my power antenna to keep it from going up like maybe at an antenna relay? Where is that relay?
I don't use the FM radio and park under aservice lift so I always forget and the antenna hits the lift and bends EVERY TIME :-)
Lee
...i think that there is a tech tip on this or a similar thread.....do a search....itsimply involves a spst switch to interrupt power to the antenna.....
The relay is under the trim beside hatch latch. You can unplug it there quite easily. I opted for a toggle switch near the ALDL connector. There are 2 pink wires leaving the back of the radio, one is for power antenna relay, the other for bose amp relay, which my memory says your not using.
Sorry,I thought he said he doesn't use the radio and just assumed, like most of us, suffered from the annoying habit of the antenna going up and down every time you slap in a cassette.
Where have you been anyway?
I thought you had been banned
Actually it interrupts the signal from the radio that activates the relay.
..it was a case mistaken identity and has since been straightened out...have been reading but, unable to post...but now....
A simple $5 on/off push button from Radio Shack wired to the antenna feed wire behind radio will do it. Then just mount the button/switch where ever you want.
I just bought a simple little toggle switch from someplace and spliced it into the pwr antenna lead. RS didn't have a push on/off when I went, only a temp interrupt (would only kill the pwr when the button was held in).
