Electronic Climate Control Panel
Old Dec 4, 2001 | 11:21 PM
dmalhi1's Avatar
dmalhi1
Default Electronic Climate Control Panel
Hi my electronic climate controls panel likes to go all haywire at times sometimes i give it a lil bash and blinks back to normal
it likes up all the lil lights behind the words. but the green numerical display turns off and so do the lil orange lights for the buttons.
somethings the orange lights start to blinky very randomly usually blinking in a sequence of rear defrost, bi-lev and front defrost and at the same time this happens my green numerical display appears to be like...... well spinning around?? whats going on??
:confused: :confused: :confused:
Old Dec 4, 2001 | 11:41 PM
vader86's Avatar
vader86
Default Re: Electronic Climate Control Panel (dmalhi1)
mine does the same thing, the numbers start blinking and then they go nuts and the orange lights flash. I figure its just a connector loose or something. Apparently the last owner had a complete idiot install a CD Changer and he really screwed things up inside my dash
Old Dec 4, 2001 | 11:48 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The first thing to do is remove the unit, pull the case & the pcb from the front panel and clean the pcb card edge contacts with an erasure.
If work has been done near your unit verify the grounds are still in tact.
Old Dec 5, 2001 | 12:12 AM
CoolVette86's Avatar
CoolVette86
From: Partying with the Cowboys cheerleaders in Mt. Olive, New Jersey
Default Re: Electronic Climate Control Panel (65Z01)
65Z is correct. Pull the unit out and clean the metal contacts. This is very easy to do. Be sure to purchase a shop manual and a Haynes manual. It's one of the best investments you can do for your car. Good luck.
Old Dec 5, 2001 | 05:59 AM
importeater's Avatar
importeater
Default Re: Electronic Climate Control Panel (CoolVette86)
mine does the same thing, a very technically oriented tool...namely my fist placed squarly on the side of the dash has fixed the problem when it happens in the past. i keep meaning to get some electric greese & clean all the contacts when i tear the dash apart next time? is it the unit that normally fails or just a connection?
Old Dec 5, 2001 | 07:06 AM
dmalhi1's Avatar
dmalhi1
Default Re: Electronic Climate Control Panel (importeater)
everyone on the forum and my buddy who owns an 86 said that its usually the connection and to clean them with a vinyl eraser. and if you see cracked solder points just touch them up with some more solder but not too much so best to get someone who knows what they're doing to do the solder work.
To Electronic Climate Control Panel
