Adjusting Door window glass height
Old Dec 5, 2001 | 02:09 AM
Turismo's Avatar
Turismo
Default Adjusting Door window glass height
My pass side door glass comes up too far and makes the door hard to close. I tried loosening the 3 window studs for the glass to move it downwards, but this does not move it enough. Is there another way to adjust the glass?
Old Dec 5, 2001 | 08:03 AM
JonM's Avatar
JonM
Default Re: Adjusting Door window glass height (Turismo)
Inside the door is a shaft-hook (the hook looks like an upside down "J")type adjuster. You have to drop the window a tiny bit and look through a hole in the door frame. Loosen the two bolts and you can adjust the height. It may take you a few tries to get it just right.
