Nash 4+3 Overdrive Question
Old Feb 21, 2008 | 06:44 PM
80vetteuga's Avatar
80vetteuga
Default Nash 4+3 Overdrive Question
I want to change the AT fluid in the OD Unit. How much AT fluid does it hold?
Old Feb 21, 2008 | 07:07 PM
c4cruiser's Avatar
c4cruiser
Takes about 2 quarts. Get some regular Dexron II/III fluid.
There is some fluid in the lines running to the cooler. You can remove both lines and use failry low air pressure to push the old fluid out.
Re-install the lines and after installing the pan, fill the OD unit. Spin a back wheel for a couple minutes to push fresh ATF thru the lines. Once you have done that, top off the OD unit.
Are you replacing the filter at the same time? You know you can get one fairly cheap ($6-$8) at part stores.
Carquest 85926
AC Delco TF 184
FRAM FT1024
NAPA ATP14717
Ford D0AZ-7A098-A (costs more at Ford!)
