Plugs and SC set up
Old Feb 22, 2008 | 06:57 AM
Pizzano's Avatar
Pizzano
Default Plugs and SC set up
Anyone running a L98 Supercharged setup, I understand it depends on all the mods doen (heads,fuel etc), but I am trying to figure out what plugs I should have in my L98, (procharger P600B, Heads supposely redone to accomadte blower with fuel pump and roller rockers)
Reason I ask, in the chiltons manual it has the stock AC Delco number, but the plug I pulled out is a diffeent number, Thanx
Old Feb 22, 2008 | 08:01 AM
silver86's Avatar
silver86
I'm running NGK FR5GP's (2 settings colder) in my L98 with a Vortech.
Old Feb 22, 2008 | 09:23 AM
Brand-X's Avatar
Brand-X
I used to run 104s in my stock heads.
Old Feb 22, 2008 | 11:35 AM
AKS Racing's Avatar
AKS Racing
AC Delco FR3LS6 in a S/C'ed application with 113s.
Aaron
Old Feb 24, 2008 | 07:18 PM
Pizzano's Avatar
Pizzano
OK i removed some plugs from the passenger side and they look normal
The lugs installed ar AC Delco 41-629, and they seem to be gapped at .030-.032,
manual calls for AC delco FR5LS for 85 and newer L98 with .035 gap.
So here is my setup , if anyone can recomend a plug and gap that would be great.
As mentioned Procharger P600B with Intercooler and fuel management with fuel pump.
Heads redone , valve job, guides, Roller rockers (dont know the ratio, but they are blue ), I was told thicker head gaskets to get the 9:1compression.
Exhaust is stock except muffler eliminators.
I have reset the timing to 6 degrees BTDC.
It also has the Hypertech race/street coil and distributor cap, MSD 8mm plug wires.
Any recomendations would be greatly appreciated.
Old Feb 24, 2008 | 08:04 PM
AKS Racing's Avatar
AKS Racing
What year is the car? If '88 - '91 (as in 113 heads), then my before mentioned recommendation still stands. You should be targeting 9.3 - 9.8:1 scr.
Aaron
Old Feb 25, 2008 | 12:05 AM
Pizzano's Avatar
Pizzano
Aaron
Yes its a 88, what is the gap recomended for the plug you mentioned.
I see the Rapidfire AC Delco #5 plugs are a replacement for the FR3LS6, FR5LS, if so are they gapped at .045. or do they come pregapped.
Thanx.
Old Feb 26, 2008 | 10:30 AM
AKS Racing's Avatar
AKS Racing
Gap at 0.032" - 0.035". I would start at 0.035" and if there are no issues, I would leave as is. The wider the spark gap (to a point), the better the idle quality will be. When you start closing the spark plug gap, the idle quality tends to suffer.
Aaron
Old Feb 26, 2008 | 01:49 PM
Pizzano's Avatar
Pizzano
Aaron
Ah that explains the somewhat rough idle as they are gapped now around .032, thanx for the info Aaron, much appreciated
To Plugs and SC set up
