injectors
Old Feb 23, 2008 | 07:45 PM
scootert96's Avatar
scootert96
Default injectors
hi i have a l98 with headers,exhaust,throttle body, and a slp cold air kit i want to put 24-26 lbs injectors on my car what do i have to do to get them to work on my car i also just ordered a afpr so what i asking can i just out the on and off i go
Old Feb 23, 2008 | 08:09 PM
FD2BLK's Avatar
FD2BLK
You need to change the injector constant for the larger injectors, you may be able to lower the FP and get close but you will still need to log data to get them dialed in and I would highly recommend tuning Vs playing with FP. I have to ask why are you changing injectors? are your stockers giving you problems if so I would just go back with the stock ones for the few mods you have they would more then suffice.
Old Feb 23, 2008 | 08:11 PM
scootert96's Avatar
scootert96
Default injectors
i was going to buy them for a mod because i have other things going on the car later
Old Feb 23, 2008 | 08:14 PM
FD2BLK's Avatar
FD2BLK
Untill you add your other mods I would hold off and do everything at once then get the car tuned, that way you will save a few $$ on tuning. The other option is do what I did and buy the tuning and data logging software and start tuning yourself.
Old Feb 23, 2008 | 08:25 PM
BAM92's Avatar
BAM92
I agree with the others. With mods you have listed, stock injectors are fine. Now if you do heads and cam, 24's are more than enough. At that point you would have to go for tune anyway. 24's will support up to 450 n/a hp.
Old Feb 23, 2008 | 09:00 PM
RRT vette's Avatar
RRT vette
I concur with the above.
Old Feb 24, 2008 | 10:40 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Don't do it until you change heads/cam.
Old Feb 24, 2008 | 12:28 PM
Demonic85's Avatar
Demonic85
you dont need them yet, just wait.
To injectors
