Accel Fuel Injectors
Old Feb 24, 2008 | 09:22 AM
89 Bob L's Avatar
89 Bob L
Default Accel Fuel Injectors
I have an 89 auto, stock, with 75K miles. I want to keep the car as stock as possible and will be changing out the fuel injectors. I am leaning towards the Accel #24 injectors and need some help.
Will I need to do anything else to the car if I use the #24's (fuel pressure, etc.). There are two injectors that Accel lists: 150124 and `50824, does anyone know what the difference is? Is one better than the other?
Old Feb 24, 2008 | 10:26 AM
Sam Lam's Avatar
Sam Lam
89 Bob L: I would not recommend that you put the 24 pounders in your 89. Doing this may add to you list of problems with the car. Some people have increased the size of their new injectors and everything was fine. However, other people have not been successful.
Why take the chance when you can get the proper sized injectors at a reasonable price? You mention the need for an AFPR and this is a must if put the 24's in your car. In addtion, you will need a scan tool to properly adjust the AFPR. Let us know what you do on this and the results.
Old Feb 24, 2008 | 10:30 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Stay with around 22 lb. Your 1989 is 21.5 at around 43 psi. Stay close to that spec. I like the Bosch injectors.
Old Feb 24, 2008 | 11:15 AM
vader86's Avatar
vader86
Ideally you would add a AFPR along with any new set of injectors, the computer can adjust to the larger spec but it needs a little help.
I know accel revised their injectors, but I still wouldnt use them.
Old Feb 24, 2008 | 11:19 AM
yellow 00's Avatar
yellow 00
I use the 21lbs accel injectors. ordered them from summit they had the best price Have not had a problem with them yet. they are the bosh style. the old ones from them were crap according to some on here.
I am very pleased with the way they perform been running them for about 8 months now
Hope this helps
Old Feb 24, 2008 | 02:57 PM
19corvette91's Avatar
19corvette91
i used the 24 lb accel from summit
had them in about 6 monthes now, no problems thus far
Old Feb 24, 2008 | 03:19 PM
89 Bob L's Avatar
89 Bob L
Thanks for the tips. I was told that the #24 injectors run at approx. 22 lbs where the #22's are at around 20? The #24's seem to be the closest to the stock injectors?
Old Feb 24, 2008 | 06:58 PM
Mickey1539's Avatar
Mickey1539
Default Fuel Injectors
I have a '91 stock L98 and I replaced my injectors last March. I purchased stock replacement Sorenson injectors from Auto Zone. The were about $46.00 each if I remember correctly. The car runs good and I haven't had any problems. Make sure you don't use a solvent type fuel injector cleaner. They desolve the insulating coatind on the electromagnet coils and then they short out.
P,S. remove all the fuel rails, it will be easer to remove and instal the injectors. The runners can stay on, just remove the plenum. Make sure you have the retainer clips on correctly. You want the O rings to seat properly.
Good luck, Mickey
Old Feb 24, 2008 | 07:41 PM
Kool88vette's Avatar
Kool88vette
Good luck, Mickey
I think you should use a light film of oil on the O rings. Don't get Accels.
Old Feb 24, 2008 | 08:21 PM
BADDUCK's Avatar
BADDUCK
See current thread "HELP"
Old Feb 24, 2008 | 09:27 PM
BobRR3's Avatar
BobRR3
Default Accel Injectors
150124 is a package of 1 the 150824 is a package of 8. They are the same injector
Old Feb 24, 2008 | 09:55 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
I have a set of Accel 24 lb injectors in my car, and I love them. The car runs great, and no, you do not need a new chip to run them. Your computer will make the adjustment w/ no problem. After my install, I could not believe how much better the car ran, and how much better the fuel mileage was.
I recommend the Accel injectors.
Old Feb 24, 2008 | 11:36 PM
RRT vette's Avatar
RRT vette
I read where increasing the fuel pressure on stock injectors actaully help the spray pattern. Usually the consensus is to add a AFPR when going with 24's on a stock engine. It's best looked at on a scan tool and see what is really going on. Search around an see what else is available. Your stock multecs, if they still are...are not servicable. I used a set of stock 88 injectors serviced by cruizinperformance in my 86 and no problems.
Old Feb 25, 2008 | 06:06 AM
MR NICE's Avatar
MR NICE
Do a search on Acell,I would go with Bosch
Old Feb 25, 2008 | 08:23 AM
88yellow's Avatar
88yellow
I put the Accel 24# from Summit and I love them. The car runs better than it ever has, and fuel milage is alot better also. I wonder if the people who say not to use them have ever used them. Lots of people seem to like them.
Old Feb 25, 2008 | 09:57 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://forums.corvetteforum.com/show....php?t=1949019
Old Feb 25, 2008 | 11:52 AM
1955VETTE2007's Avatar
1955VETTE2007
Cruising
Default link to who knows injectors
these guys are great and they have a 87 vette. i used them for my car after all kinds of fi problems with excell. i went with the bosch new design. 22lb. they don't absorb heat and the car runs like a clock. make sure to get viton o rings
www.fuelinjectorconnection.com
To Accel Fuel Injectors
