No MAF L98 ?
Old Feb 25, 2008 | 07:48 PM
Calderone's Avatar
Calderone
Default No MAF L98 ?
I was told that a no MAF version of the L98 exist
i got no maf...or maybe they just throwed it away ! (ex owner)
is it true ?
thanks!
Old Feb 25, 2008 | 08:07 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
Yes - in 1990 and 1991, the L98 used a speed density system which calculates air flow based on MAP (manifold pressure).
Old Feb 25, 2008 | 08:32 PM
Calderone's Avatar
Calderone
thanks
my 1987 MAF is nowhere to be found
i really dont know how my car used to start without the MAF
Old Feb 25, 2008 | 08:52 PM
Speed Hound's Avatar
0Speed Hound
Former Vendor
Is there by chance a computer mounted above the battery off the firewall? It would be painted black. What about a MAP sensor mounted on the upper plenum on the passenger side of the engine? Maybe the car was converted to speed density and the simply swapped in the engine, ECM, and wiring from a 90-92 car. It would look stock then to most people.
Old Feb 25, 2008 | 09:04 PM
tequilaboy's Avatar
tequilaboy
The MAF equipped cars can run very well without a MAF, but this usually takes some specific chip tuning.
To protect for a MAF failure, there is a default airflow calculation that approximates the MAF signal. This can work very well when properly tuned.
Did you have an SES lamp on all the time? If not, it could be that the chip's programming has been modified to disable the MAF related codes 33, 34 and 36 with the intention of running "MAFless". I've done this myself and I know of a few cars that have also used this method.
Perhaps you just got lucky and your car ran ok with the default tuning, which is certainly possible.
Old Feb 25, 2008 | 09:21 PM
86GoldProject's Avatar
86GoldProject
can you take a pic of your engine bay so we can see what you're working with? It may help shead some light on what's going on.
Old Feb 25, 2008 | 09:49 PM
anesthes's Avatar
anesthes
Could also be in limp home mode eh? On a stock car I hear that actually works. On everything I've ever built, it was more like push-home mode.
Someone also could have repinned it to speed density (like me) since the '730 fits in the dash just as nicely as the '165 did. Unless we see some pix (or the car) who knows.
-- Joe
Old Feb 25, 2008 | 11:32 PM
Calderone's Avatar
Calderone
Ok but it looks like this :
But it used to look like this :
Someone put a white piece of plastic where the MAF is supposed to fit:
my mileage :
Old Feb 26, 2008 | 05:49 AM
anesthes's Avatar
anesthes
my mileage :
Crawl up under the dash, let us know if the ECM has 2 plugs or 3. Write down the number off the ECM.
The pix are helpful - you have NO maf sir! Now we need to figure out how.
-- Joe
Old Feb 26, 2008 | 06:32 AM
Calderone's Avatar
Calderone
thanks ! i will do that when i go to work on the car this week..but ..where is the ecm exactly located ?
thanks !
Old Feb 26, 2008 | 09:07 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
thanks !
Remove the footwell panel on passenger side and you will see the large wire bundle heading up into dash. ECM is held in with two 10mm screws.
Lay on your back and you will be looking right at it.
Old Feb 26, 2008 | 10:02 AM
Calderone's Avatar
Calderone
thanks but how can i know if its a MAF or NON MAF ecm ?
Old Feb 26, 2008 | 10:07 AM
AGENT 86's Avatar
AGENT 86
-- Joe
Old Feb 26, 2008 | 12:54 PM
Muffin's Avatar
Muffin
There should be a part number on the ECM. If it is 1227165 it is a MAF ECM. Not sure but I think the later non-MAF ECM ended in 730.
Old Feb 26, 2008 | 01:04 PM
mseven's Avatar
mseven
yes, the sd/map could be either, a 727 or 730
Old Feb 26, 2008 | 04:33 PM
anesthes's Avatar
anesthes
Yep, the '730 is a fbody ecm. (well it was used in all kinds of things actually) and fits in the dash nicely. '727 would be vette, and I think some holden cars ran a '727.
I totally spaced - you can still run map in a '165. I forget the mask ID but it's a holden based thing. You still have to repin the ECM to run it, but a few fbody guys who didn't wanna spend the extra $75 on a '730 + memcal did it that way.
-- Joe
Old Feb 26, 2008 | 07:12 PM
AKS Racing's Avatar
AKS Racing
There is no MAP installed where a 90-91 MAP would have been located. I would suspect that it failed and someone did a "quick fix".
Aaron
To No MAF L98 ?
Old Feb 26, 2008 | 10:39 PM
Calderone's Avatar
Calderone
what consist for the quick fix ?
thanks
Old Feb 27, 2008 | 06:55 PM
86GoldProject
the right way or the wrong way? The wrong quick fix would be what the previous owner did, simply unplug the maf and put a tube in its place. The correct quick fix would be buy a maf, install it where the tube was and plug it in. These cars actually run pretty decent without a maf, the pcm simply uses a default value since it isnt receiving a signal from the maf sensor, which is why your car ran without it. Buy a new sensor and put it in. If the check engine light isn't on its probably because the previous owner took the bulb out, if that's the case replace the bulb too.
Old Feb 27, 2008 | 08:02 PM
Overboost's Avatar
Overboost
From: Flint Michigan, #2 in unemployment, #3 in Violent crimes
I was in the turbo buick scene for a while (we brake for corvettes) and they can convert the MAF system to a non MAF setup that still learns. the guy is here in michigan that does it but I am sure you can do this with other cars and not just a grand national. the higher HP guys would delete the MAF for dependability.
it is not completley beyond the rhelm of possibilty that you can do this with nothing more than an ECU mod and correct wiring upgrades.
and my 90 IROC came factory with NO MAF, same engine, just change things out.
