I have just replaced the window regulator in my 93 LT1. Putting all back together I see that the outer door seal have clips that clip into holes in the door. Mine are pretty bad so I would like to replace them. The aftermarket ones have rivets. Will I have to remove the window again to install???? I just got the window nicely aligned and would hate to take it out again. Thanks for the advice.
Just does not look like I will have much room to do any riveting with the window in place. I have loosened the window pads. I guess I will just have to get in there and give it a shot. Thanks.
Memory says I could not install one of the rivets due to the glass. The clips do a good job holding it, so missing one or two rivets is livable.
I did the ones on my 92 this past fall. All you have to do is take off the door panels. I got all the rivets in. It took some maneuvering to get the rivet gun just right but they all went in.
