quick thermostat question
Old Mar 2, 2008 | 11:30 PM
cwyates4's Avatar
cwyates4
Default quick thermostat question
I just need to know if there is a specific type of thermostat I need for my miniram. Mine went out today, spewed some coolant out the resovior and got up to 262 degrees , no damage though. It had a 180 degree thermostat in it, but I've heard of needing a special tstat for minirams. Any ideas?
Old Mar 2, 2008 | 11:52 PM
Kool88vette's Avatar
Kool88vette
I'm sure this will be interesting. I like a 160 thermostat. It works well with my superram. Why would the miniram require a certain thermostat?
Old Mar 3, 2008 | 12:03 AM
cwyates4's Avatar
cwyates4
It appears to be quite thin compared to the stock style intakes. Over on thirdgen.org (f body forum), I've heard of the t-stat bottoming out on minirams. I guess I'll just throw a 180 in, but would a 160 be better? Wouldn't mess with the computer or cause the car not to get to proper operating temps would it?
Old Mar 3, 2008 | 12:09 AM
Kool88vette
http://gmtips.com/3rd-degree/dox/tips/cool/cool.htm
Check out the link. If the 180 worked well stick with it. I live in a hot climate.
Old Mar 3, 2008 | 02:29 AM
Curveit's Avatar
Curveit
Some people had trouble here on this Forum too. I think it was early castings of the Mini Ram that had the problem. You can take the old one with you to compare, right?
Old Mar 3, 2008 | 09:10 PM
cwyates4's Avatar
cwyates4
The mechanic said it looked like a standard thermostat, so he threw a 180 in and everything is great. It occasionally was getting hot, so hopefully the thermostat was the issue.
Old Mar 3, 2008 | 09:18 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
I have no idea what car you have, but a quick check on the TPiS site says they rec. 170* on L98's and 160* on LT1's. Not that I agree with that, just passing it on. It would be helpful if you would fill out your profile or identify the year.
Old Mar 3, 2008 | 09:28 PM
89onlyZ51's Avatar
89onlyZ51
some info anesthes posted over on TGO...
http://www.thirdgen.org/techboard/al...ck-issues.html
Old Mar 5, 2008 | 12:26 PM
cwyates4's Avatar
cwyates4
I drilled holes in the thermostat today and the problem is now solved. I guess I just had a nasty air bubble under the tstat. Also, the tstat isnt bottoming out, the miniram is the newer style with the recess being in the water neck.
To quick thermostat question
