Is there a torque spec for Knock Sensor
Old Mar 4, 2008 | 01:38 AM
Pizzano's Avatar
Pizzano
Default Is there a torque spec for Knock Sensor
1988 Knock sensor, is there a specified torque for this part, or do I just do what I did and tighten until I felt it was tight enough before I snapped it off.
I also use Blue thread sealant, didnt want to use red in case I would have to remove it anytime.
Thanx folks.
Old Mar 4, 2008 | 02:50 AM
USAsOnlyWay's Avatar
USAsOnlyWay
There is a torque spec, I don't have my Helms in front of me, but I want to say it is around 7-15 lb/ft but its been a few years since I installed one.
Old Mar 5, 2008 | 11:18 PM
AdoptAVette's Avatar
AdoptAVette
Torque on a '91 knock sensor is 14ft/lbs.
Most sensors you buy already have sealant on the threads. There is no need for more.
Old Mar 5, 2008 | 11:43 PM
staugur's Avatar
staugur
88 is the same.OEM should come with sealant applied and you should not use any more.Especially teflon as someone recommended.
Old Mar 6, 2008 | 11:02 PM
Corvette0096's Avatar
Corvette0096
Old Mar 7, 2008 | 07:49 PM
cmontel727's Avatar
cmontel727
14lbs and no extra sealent when I did mine
To Is there a torque spec for Knock Sensor
