where is it?
Old Dec 6, 2001 | 05:42 PM
LayZ's Avatar
LayZ
Default where is it?
I have a fastchip comming. Where is the prom located in a 86 vette?
Old Dec 6, 2001 | 06:05 PM
ZylaRace's Avatar
ZylaRace
Default Re: where is it? (LayZ)
The only BowTies I'll be wearing are on my front emblems! :chevy
Getting a PROM or a MemCal?
MemCal: plug it into ECM n go.
PROM: unsolder old, resolder socket, plug it into MemCal, plug it into ECM n go.
ECM in an 86, in dash, pass side foot well area. (As I recall.)
Two screws on case expose MemCal module.
Neck type bowties,... :U
Old Dec 6, 2001 | 07:18 PM
Rich B.'s Avatar
Rich B.
Easy to get at. Sit in pass seat. Now, turn until head is where feet were, and feet are where head was. You'll see 3 screws (7mm) holding plastic panel in - the one with the light in it. Undo them; disconnect light connection. Look up in cavity; you'll see a white or creamish rectangular plastic bracket holding an aluminum box in. There are two harness connectors going into the box. Undo the connectors (squeeze if blue plastic; pry outward with screwdriver if metal clips) and pull off. (Don't worry - disconnecting it won't hurt anything!). Now undo the two screws (10mm) holding the plastic bracket. The ECU (the alum box) may drop right out; if not, just pull it out.
The long alum strip on the ECU covers the MemCal (Memory Calibration unit). Unscrew it; push off the two end clips holding the MemCal (the blue thing). Push the new one in. Reconnect harnesses (leave ECU dangling); take for test ride.
Re-assemble when satisfied with testing. The second and later times you do it, you can get away with stealing your wife/mom/girlfriends' bathroom mirror, and just kneel next to the seat looking up with the mirror and take it out.
After 10 - 12 times, you'll have it down to less than 5 minutes, all told. :crazy:
[Modified by Rich B., 6:19 PM 12/6/2001]
Old Dec 6, 2001 | 07:24 PM
pablocruise's Avatar
pablocruise
Default Re: where is it? (Rich B.)
Dramamine helped me on this part :D
To where is it?
