86 EGR Valve Temperature Switch
Old Mar 5, 2008 | 07:02 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Default 86 EGR Valve Temperature Switch
I am installing a new EGR Valve Temperature Switch in my 86 roadster. This seems like an easy enough chore, but the switch connector is down behind the distributor and very difficult to get to. You can barely hold onto it with your finger tips which makes it near impossible to use your other hand to snap the male connector into place. Any ideas about how to make this snap connection without removing the distributor? Any help will be appreciated.
Old Mar 5, 2008 | 07:33 PM
_twisted_'s Avatar
_twisted_
I used a hook tool to grab the other side of the connection so it didnt drop out of sight if I recall, and taking the cap of the dist helped a lot
Old Mar 5, 2008 | 08:58 PM
Bob CTS's Avatar
Bob CTS
Pete -
When I replaced mine I took the plenum extension off and then took off the distributor cover, did not remove the wires and was able to get to it w/ no problem.
Bob
Old Mar 5, 2008 | 09:05 PM
Chatman's Avatar
Chatman
I managed to use long needle-nosed pliers but it was a PAIN.
Old Mar 5, 2008 | 09:11 PM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
What symtoms were you having to make you need to change the EGR temp. switch? Was it hard to start when hot?
Old Mar 5, 2008 | 09:27 PM
geezel's Avatar
geezel
When I had my distributor off, I lengthened the wire. (Plenty of access without the distrib.)
Old Mar 5, 2008 | 09:47 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Glad I don't have one.
Good luck
Old Mar 6, 2008 | 12:22 AM
staugur's Avatar
staugur
Good luck
Somebody stole all my emissions stuff.
Old Mar 6, 2008 | 12:28 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Originally Posted by rspreng02_Z06
Pete -
Bob
Thanks guys for your input. I was able to get a string around the female coupling and move as many wires & cables out of the way enough to get to it with great difficulty. After 3-4 hours of fiddling with it, I finally got it in without taking the distributor cap off. What a PITA !
I was replacing the aluminum foil heat shield on the EGR tube and thought that while I was in there I would replace the EGR switch since I had to uncouple it to get the new heat shield in place. All this as part of my NCRS Top Flight preparation. Thanks for your help and encouragement.
To 86 EGR Valve Temperature Switch
