wind deflectors?????
Old Dec 6, 2001 | 09:51 PM
24power's Avatar
24power
Default wind deflectors?????
Anyone using the wind and noise deflectors that mount on the mirrors??? If so, did you rivet them on???...Have seen several differant styles. Which one better fits the contours of the mirrors?????/
Old Dec 6, 2001 | 10:09 PM
85vet's Avatar
85vet
Cruise-In V Veteran
Default Re: wind deflectors????? (24power)
I did purchase a set to install over the winter. I have been considering if I should have them painted. But they will match the minimal amount of black on the car.
I bought the set with double sided tape, but they can always be rivetted.
If you use the tape, you can always take them off with no holes.
The contour does go with the mirrors.
:flag :chevy
[Modified by 85vet, 9:10 PM 12/6/2001]
Old Dec 6, 2001 | 10:23 PM
24power's Avatar
24power
Default Re: wind deflectors????? (85vet)
Saw a few differnt styles>>>where did you get yours?????
Old Dec 6, 2001 | 10:42 PM
Hardcorvette's Avatar
Hardcorvette
St. Jude Donor '06-'07-'08-'09-'10
I purchased a set from Mid-America...around $25.00, they come with 2-sided tape AND rivets. I currently have them attached with the 2-sided tape...I'm a little leary about drilling holes in my mirror housing. It's been about a month and so far they have held up well, and they really cut down on air deflection/noise coming into the cabin. I highly recommend them! :cheers:
Old Dec 6, 2001 | 10:50 PM
85vet's Avatar
85vet
Cruise-In V Veteran
Default Re: wind deflectors????? (Hardcorvette)
I purchased mine through Zip here on the forum. Paid 23.70 and includes the double tape and rivets as well.
Jim C
Old Dec 6, 2001 | 11:27 PM
LT-IV's Avatar
LT-IV
I had mine taped on and after a while they loosened up.
I used a couple of small metal screws. So far it's held up good.
BTW: I found they really help cut down the noise.
Old Dec 7, 2001 | 12:18 AM
CAPN17's Avatar
CAPN17
I bought a set of GM wind deflectors and installed them on the car. The tape is OK to use to position them, but it does not hold for beans. I used three pop rivets, alum. ones, then used some black touch up paint to cover the heads.
Old Dec 7, 2001 | 12:42 AM
scorp508's Avatar
scorp508
They came stock on my car, and are riveted in place.
Old Dec 7, 2001 | 12:53 AM
Admiral Fairway's Avatar
Admiral Fairway
Also installed mine with rivets, couldn't get the double sided tape to hold. By the way on certain years they came standard on convertibles.
Old Dec 7, 2001 | 12:55 AM
GlockLT4's Avatar
GlockLT4
I have the wind deflectors.. they are on with screws. Hold them on fine... don't make any rattling noises and compared to other vettes i've ridden in, it sounds a lot less windy noisey around that area.
To wind deflectors?????
