85 drivibilty
Old Mar 6, 2008 | 02:28 PM
headaches's Avatar
headaches
Default 85 drivibilty
Hello My 85 does not accelerate under load just pops back into the intake,Ran codes pulled 33 MAF sensor voltage.Tested connector power present on all three tests ran the final voltage check found 7 volts at sensor next step is to dis-connect connector A-B on the ECM and re-test.I dis connected each connector seperately and tested and there is no voltage at the MAF either time.Anyone familiar with this issue and which connector is which on the ecm? Any help will be greatly appreciated
