Window won't roll up
Old Mar 7, 2008 | 03:53 PM
1989vette's Avatar
1989vette
Default Window won't roll up
Hi all i have an 89 coupe, and this problem just started. on my way home last night i rolled the windows down and when i went to put them up after i got home they would not go up. I haven't driven the car for about a month but before that they would roll up just fine. Now they will not go up, this is both windows. Thanks in advance for the help
Old Mar 7, 2008 | 04:01 PM
geogolf's Avatar
geogolf
Default windows
did you check fuse
Old Mar 7, 2008 | 06:26 PM
1989vette's Avatar
1989vette
Originally Posted by geogolf
did you check fuse
would the fuse let them roll down but not up? i have not but i will
Old Mar 7, 2008 | 06:57 PM
geogolf's Avatar
geogolf
Default windows
fuse could of blown after you rolled them down but that is what i would check first then maybe connections
Old Mar 7, 2008 | 07:44 PM
CFI-EFI's Avatar
CFI-EFI
There aren't a lot of things that would affect both windows at exactly the same time. The fuse is one of those few things. A bound up or broken regulator could keep a window from moving, but both regulators at the same time? No, a blown fuse won't let the window down and then not back up. If the fuse blew, it happened between putting the windows down and trying to raise them.
RACE ON!!!
To Window won't roll up
