Cam and what else?
Old Mar 8, 2008 | 01:58 AM
LT1CDNRICK's Avatar
LT1CDNRICK
Default Cam and what else?
Hi guys,
Im working on my 94 vette auto
Just installed
-comp cam276hr-14
-comp lifter,push rods , springs and roller rockers.
-msd opti, wires and coil.
I was thinking of adding a BBK 52mm throttle body, k&n Filter and a cat back exhaust system.
Any ideas what kind of gains i would get with the whole package?
Plus what is a good cat back system?
Old Mar 8, 2008 | 03:56 AM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Originally Posted by LT1CDNRICK
Hi guys,
Just installed
-comp cam276hr-14
Don't waste you money on the throttle body.
Old Mar 8, 2008 | 08:36 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Hi guys,
Just installed
-comp cam276hr-14
None of that will add much HP. Get a good tune.
Old Mar 8, 2008 | 09:02 AM
chad89's Avatar
chad89
and headers
Old Mar 8, 2008 | 12:45 PM
racebum's Avatar
racebum
i have that same cam, the 224/230 XR, works great, easy to drive and good for 350rwhp with nice heads and a good tune. headers are a must, same with the tune. the TB didn't gain me even a single tenth in the quarter. with stock LT1 heads, nice headers and a good tune you should be somewhere around 300rwhp maybe a touch more. that cam also likes to peak around 6000rpm so be careful with your bottom end if it's 100% factory.
Old Mar 8, 2008 | 01:22 PM
STL94LT1's Avatar
STL94LT1
Response delete for "not paying attention".
Old Mar 8, 2008 | 02:54 PM
BADDUCK's Avatar
BADDUCK
Originally Posted by STL94LT1
You don't think a camshaft will increase horsepower, and a tune "will" on a mostly stock engine?
You didn't read his post, he already HAS the cam, RR's, etc. . He's thinking of adding throttle body, cat back, etc.
I said those won't add much, get a tune! Get it! If he has changed the cam he NEEDS a tune.
Old Mar 8, 2008 | 03:02 PM
MK 82's Avatar
MK 82
Go back and read what he really said.
Old Mar 8, 2008 | 05:03 PM
STL94LT1's Avatar
STL94LT1
OOPS, sorry, didn't get much sleep last night.
I'm with the tune.
Old Mar 8, 2008 | 05:51 PM
LT1CDNRICK's Avatar
LT1CDNRICK
Sound like i should work on the tune and the exhaust side of things.
Thanks for the input!
Old Mar 8, 2008 | 08:53 PM
racebum's Avatar
racebum
here's how that cam sounds with a good exhaust and some aftermarket heads
http://www.mediafire.com/download.php?6eboo2mvxv1
not a dial up friendly download 5.7mb burnout vid
To Cam and what else?
