LT1/4 intake remove, drain coolant?
Mar 8, 2008 | 01:11 PM
I just read in my Haynes manual, getting ready to do the intake gaskets on my lt4.
Is states that i need to drain the coolant, is that really necessary?
I can see it needed on the L98, but is there any coolant in the intake on a LT4
It also states that i should apply permatex on the coolant holes in the gasket facing the heads..?
Mar 8, 2008 | 01:17 PM
You can remove the intake without draining the coolant, it is a dry intake. Just don't disconnect the coolant hose through the throttle body.
Also, don't use sealant on the intake gaskets.
Mar 8, 2008 | 07:16 PM
Mar 9, 2008 | 08:51 AM
Is this also true for an Lt1, I have to replace the intake manifold gaskets on 92 LT1.
Mar 9, 2008 | 12:02 PM
Quote:
Originally Posted by
lilredc4
Yes.
Mar 9, 2008 | 12:07 PM
Quote:
Originally Posted by Lars87
I just read in my Haynes manual , getting ready to do the intake gaskets on my lt4.
Are you starting to catch on about the Haynes manual?
RACE ON!!!
Mar 9, 2008 | 12:44 PM
Can you disconnect the throttle body from the intake without draining the coolant, or must you leave it attached to the intake.
Mar 9, 2008 | 12:48 PM
Yes you can disconnect the throttle body from the intake without draining the coolant. Now might be a good time to do the TB coolant bypass mod.
Mar 9, 2008 | 01:06 PM
1995 ,
coolant ,
corvette ,
drain ,
draining ,
gasket ,
gaskets ,
holes ,
intake ,
lt1 ,
manifold ,
remove ,
replacing
