[PICS] Busted a titanium spring retainer...
I was on my home from work and heard a "ticking" noise, and at the time I thought that it was just an exhaust clamp that had worked itself loose. However, after I pulled the car into the garage and listened to it I realized it was certainly NOT an exhaust leak. It was very easy to tell that the noise was coming from under the drivers side valve cover...so I then thought make a rocker-arm had worked loose. But after I took the valve cover off I saw the real reason.
This is what's left of one of the expensive titanium retainers;
Thankfully the valve didn't drop into the cylinder because the inner valve spring held the center of the retainer. I haven't done a leak-down test yet but at this point it seems that there is no real damage, other then the retainer. But of course the question remained about what caused it to break, so we took off the other spring on the cylinder to look at it's retainer and found out that it was on the verge of failure as well...and at this point I'll assume that the other 14 are in similar shape.
What's happening is that the coil that is placed between the inner and out springs is "chewing" it's way through the retainers. Here's a pic of another retainer I took off the engine;
No here's another pic with the inner coil placed in the groove that shouldn't be there...as you can see they match up perfectly.
I never thought anything like this could happen, I'm guessing that there is only about 15,000 miles on the springs and retainers, but I could be off on that. So now we are in the process of replacing all the springs and retainers, but this time we filed down the leading edges of the coil to try and make sure this doesn't happen again.
Anyone else see anything like this before?
surrounded by the aura.
There appears to be small fragments from the 'machining' performed
by the damper springs. Have you considered cutting open the filter
for inspection?
The oil pump gears would be susceptible to damage from fragments
small enough to pass through the pick-up screen. Larger fragments
may be gathered on the outboard side of the screen.
The rear main bearing receives unfiltered oil from a passage directly
upstream of the pump. Other points in the lubrication circuit receive
filtered oil with the caveat that there is a by-pass valve in the adapter
that the filter threads onto. Under certain cold-start/viscosity/RPM
conditions where the filter is unable to pass sufficient fluid, pressure
is relieved at the by-pass valve, allowing unfiltered oil past the filter.
Ti retainers are non-magnetic.
Consequently, any fragments that shed are free to roam unhindered by
magnets that might be situated around the valley or bottom end.
I actually had a tear-down for this engine planned for late summer...I may move that date up by a bit!
I'm still in shock at how good the situation has actually been so far, all things considered!
I'll keep an eye on them for a while and see of rounding off the edges of those springs helped or not. If I see the same type of wear then I'll just switch over to steel retainers. I don't need the titanium ones, but they are better for higher revving motors, but my 7200 RPM rev-limit doesn't really require them.
I guess for now, anyone who has Ti retainers with some healthy springs might want to consider taking a look at them sometime!
Larry
I'm hoping that grinding down that middle coil will help things. However, I will be pulling a couple of them back off in a month or so to see if they show any signs of repeating this. If so then I'll switch over to some lightened steel retainers and be done with it.
I experienced similar 'wear' from the damper between the springs, but definitely not to the same degree.
Speaking with my machine shop (primarily off road engines), they stated that Ti retainers are throw aways...ie. should be replaced routinely. It is a softer metal so made sense. I switched to the beehive springs with the appropriate smaller retainers out of non-Ti materials.
Solved my valvetrain crash at 6200 rpm (along with an AFR Hydra rev kit).
