1990 CYL head torque specs
Old Mar 11, 2008 | 05:22 PM
SCCA VETTE's Avatar
SCCA VETTE
Default 1990 CYL head torque specs
? Anybody have the torque specs for 1990 L98? And yes I tried using the search and was unable to locate the numbers.
Phil
Old Mar 11, 2008 | 05:57 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
It's in the manual.
Old Mar 11, 2008 | 06:06 PM
SCCA VETTE's Avatar
SCCA VETTE
Originally Posted by BADDUCK
It's in the manual.
Well thank you for that bit of knowledge
Old Mar 11, 2008 | 06:24 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
67 or 65 lbs. I forget which.
Old Mar 11, 2008 | 06:30 PM
BADDUCK's Avatar
BADDUCK
I had no idea someone would tear an engine down without one. Good luck!
Old Mar 11, 2008 | 06:56 PM
SCCA VETTE's Avatar
SCCA VETTE
LOL Do it all the time. The problem I ran into is that it has factory allum heads and wanted to see if it was 65 FT LBS like a Iron head SB.
I did a little research and seems up through late 88 the torque specs were 65 for the long and medium bolts and 60 on the short bolts.
In 89 it changed to 67 FT LBS on all bolts. I wonder if this was one of the cures for the gaskets blowing?
SOURCE = ALLDATA
Anyways thanks for the post
Old Mar 11, 2008 | 07:02 PM
Pete K's Avatar
Pete K
If memory serves, short bolts are 60, all others are 65. I usually torque all to 65.
Old Mar 11, 2008 | 07:06 PM
SCCA VETTE's Avatar
SCCA VETTE
OOPS you are correct ! Fixed That is what get for typing while i watch family guy
Old Mar 11, 2008 | 07:08 PM
gw962's Avatar
gw962
Unless someone beats me to it, I'll post the numbers out of the FSM for my 90 tonight.
Old Mar 15, 2008 | 02:00 PM
gw962's Avatar
gw962
I apologize for my tardiness... My FSM shows 67 lb/ft
Old Mar 15, 2008 | 02:12 PM
BADDUCK's Avatar
BADDUCK
This explains a lot!
To 1990 CYL head torque specs
